Skip to content
Passenger Side
1980 MCI-9 CONVERSION
Description
Bus Year 1980
Motor Detroit diesel 8V-71
Bus Location Bonners Ferry, Idaho
Sellers Name Darla
Contact Number (208) 351-5719
Price: $29,500
Item Description
1980 MCI-9 CONVERSION, is 2/3 Complete. With the professional advice of our friends at Custom Land Yachts in Maine, we built this beautiful conversion.
MECHANICAL, ELECTRICAL, PLUMBING INSTALLED. The bus has been stripped to the frame, rust proofed & spray urethane foam insulated, in all walls and roof, to keep you warm in winter & cool in the summer! Adding to that R-value is the exceptional CUSTOMIZED STORMTITE, tinted, R-35 Dual Pane Sliders with screens. The upper aluminum skins have all been replaced when new windows installed, including the driver’s window! All wheels have EAGLE STAINLESS STEEL WHEEL HUB CAPS!
No cutting corners here! All PROFESSIONAL TOP OF THE LINE COMPONENTS. Even the newer conversions can’t compete with these!
*KUBOTA 8KWH DIESEL GENERATOR, FULLY ENCLOSED, REMOTE START, ALMOST SILENT, LOW HRS.
*Rear bay holds the AQUA HOT 50,000 BTU PROPANE FIRED BOILER, that supplies your ON-DEMAND DOMESTIC HOT WATER, the IN-FLOOR HEAT SYSTEM and THE INSULATED PLUMBING BAY HEAT for WINTER USE! *2-100 GALLON FRESH & GREY WATER TANKS are in the heated bay.
*4-30 lb. PROPANE TANKS, the household BATTERIES, INVERTOR & GENERATOR are in the front bay, for easy organized access. Middle bay holds your additional, 70-gallon diesel fuel generator tank with lots of WIDE OPEN FOR STORAGE & TRAVEL GEAR! All of the bays have electric outlets for exterior use.
*40,000 BTU, SUBURBAN FHA propane-fired heater for quick heat on those cool days.
*3 DUO THERM 13,500 BTU rooftop air conditioners, plus a temperature controlled FANTASTIC VENT FAN in the bath area.
*BUS A/C AND HEAT are still in place for over the road comfort! No need to run your generator to heat or cool this coach while driving
*INTERIOR IS A CENTER ISLE DESIGN, makes for a great entertainment coach. All walls are Marine grade plywood with light gray laminate. FLOORS are SOLID OAK PLANKING with In-floor heat.
*FLEX STEEL, LEATHER swivel recliner & sleep sofa, medium gray with storage underneath! For the driver, only the best in comfort! A BOSTROM ADJUSTABLE AIR RIDE SEAT! All in NEW CONDITION BARELY USED!
*REFRIDGERATOR IS A 3 WAY DOMETIC. While on the road you can use your 12v to keep the fridge cold, unlike other buses that must run their generator!
*MARINE STOVE/ OVEN, STAINLESS STEEL & GIMBALLED so you can cook while you travel!
*SEA/LAND DOMETIC low water use, toilet & porcelain sink. Shower plumbing installed. Will need to install a shower stall.
The bus is operational, the hard stuff is done, just needs someone to give her the finishing touches! You design your bedroom cabinets, valances & blinds, counter tiles, cabinet doors, and some electric fixtures. Has 2 Brand new Bus batteries, will need a set of house batteries. Add a paint job and you have a rock star on a bus!
OVER 90,000 INVESTED, components alone are worth more than the asking price! MCI-9’s ARE A HIGHLY SOUGHT-AFTER BUS FOR CONVERSIONS, DURABLE AND WELL-BUILT WARRIORS. The Detroit diesel 8V-71 engine has 95,000 on rebuilt motor, runs & starts well!
$29,500 you will be stealing her!
Darla; 208-351-5719 OR EMAIL; busingdaze@yahoo.com PLEASE, serious inquiries only!
BUS LOCATION, Bonners Ferry, Idaho
Contact the seller about this item by e-mail
Please enter your name.
Please enter a valid phone number.
Please enter a message.
Scroll To Top
