Skip to content
outside
1992 Genesis
Description
Bus Year 1992
Motor DT360A
Bus Location Hendersonville, NC
Sellers Name Luke and Rachel
Contact Number (828) 702 9333
Price: $75,000
Item Description
Chassis specs
Year: 1992
Make: AmTran
Model: Genesis
Engine: DT360A
Transmission: Allison AT545
Mileage: 135K
Overall length: 36’
Overall height: 12’ 9”
Roof raise: 20”
Electrical systems
920 watt solar array
2000 watt inverter and 140 watt aux inverter
30 amp shore power connection
500Ah battery bank
Plumbing
100 gallon fresh water tank
93 gallon grey water tank
High volume water pump
Water filtration system
Composting toilet
RV type waste dump valve
5 gallon RV water heater
Propane system
Two removable 20 lb tanks
One 17 gallon fixed tank
Auto change-over regulator
Appliances
NorCold two-way propane/electric fridge W/ freezer
24” stainless steel Avanti propane range oven
24” stainless steel Broan range hood w/ light
Furniture/accommodations/storage
Fold down black walnut dining table
6’4” sofa w/ one integral seat belt. Sofa folds into bed and has storage underneath
Built in end table with fold up top for storage
Wood burning stove on copper hearth
Wood storage cubbies
Built in dresser and closet
Queen bed loft
Toddler bed w/ storage
Toddler space/room w/ drawers and shelves
Cherry staircase up to loft with storage built into stairs
Large exterior garage storage space
Two exterior under body storage compartments
Other features
RV double pane insulated glass windows
Spray foam insulation
Emergency exit window on each side
Custom hardwood cabinets
Solid bamboo flooring
Luxury driver’s seat
Awning
New/replaced/upgraded parts
Transmission and torque converter replaced less than 12,000 miles ago
4 new rear tires
New water pump
New rear air brake chambers
New larger radiator
New turbo charger piping
New transmission cooler lines
New starter battery
Visits: 343
Contact the seller about this item by e-mail
Please enter your name.
Please enter a valid phone number.
Please enter a message.
Scroll To Top
