Editor’s Note: Crawling under a bus can be very dangerous. If you are not familiar with your bus’s suspension system, or your jacks, then you should take your bus to a heavy-duty bus or truck mechanic. People are killed every year by jacking them up improperly, by airbags that blow out unexpectedly, or when they fall off blocks and other support items that should never be used for jacking up a bus. Neither I nor Bus Conversion Magazine assumes any liability for what you do or how you do it.
Unfortunately, many bus conversion owners do not maintain their bus as they should, having been erroneously led astray by mechanics, friends, YouTubers, and old wives’ tales (it’s a million-mile motor for example). If you’re looking to purchase a coach, or you just bought one, here are some things to consider.
Your bus will reward you when properly maintained with safety, reliability, comfort, and peace of mind. Our bus moves us roughly 50,000 miles a year, and we never worry when hitting the road.
Maintenance will always cost less than repairs, and won’t leave you stranded. The following list applies to both someone inspecting a bus for purchase, or once it’s yours to make sure it’s safe and reliable.
If you are considering a coach to purchase, ask the current owner for the service history (with invoices for proof), and what their maintenance schedule is. (Unfortunately, many bus charter companies, destroy the maintenance records before selling their buses for liability reasons. If you buy one of their buses, it is up to you to inspect their buses thoroughly.)
Many owners maintain their coaches properly, and keep meticulous records, while some live in blissful ignorance and repair their bus when something breaks. The following list is only for the mechanical side of the coach, the conversion side will be dealt with in a future article.
Doing the above verifications properly will take 4-5 hours, will require some tools, and a safe way to get under the bus. The suspension and brakes are not to be trusted if you’re crawling under the bus. Properly support the bus with the factory jacking points and block the wheels to prevent your bus from rolling when the brakes are released.
After you get the coach home, it could take a few days to replace all the fluids, the air dryer, shocks, etc. Taking the time to put your coach in safe running condition will give you a solid foundation to go from and allow you years of enjoyment.
Learning what to look for and how to maintain your coach will save you thousands of dollars over the life of your coach, and give you the confidence that you know the condition it’s in. Remember, breakdowns on the road, can cost significantly more than when you are home with a known mechanic.
DO YOUR PART TO KEEP OUR ROADS
AND HIGHWAYS SAFE AT ALL TIMES!
7-Step CDL Air Brake Check
CDL Air Brakes – 7-Step Check According to HYPERLINK “http://dotmobileinspec-tions.com/” DOTMobileInspections.com
The 7-Step Air Brake check is designed to test the governor cut-in and cut-out pressures, air pressure leakage, warning buzzer, brake valves, and air pressure rebuild rates. Perform these steps in the order listed below.
If there is a problem discovered while testing the Air Brakes, do not drive the vehicle. Never operate a vehicle that is unsafe to drive.
It is your responsibility to make sure it is repaired by a qualified mechanic.
You can follow along with their conversions and travels on Facebook, Instagram, and YouTube.
You may contact Yvan at: yvan1lacroix@icloud.com
