• National Bus Trader Banner AD
  • Straight Line Banner AD
  • Bus Manuals Banner AD
  • Midwest Bus Parts Banner Ad
  • Unforgettable Fire Banner AD
  • Flame Innovation Banner AD
  • Thinkware Dash Cam Banner AD
  • Tire Table New Banner AD
  • Ardemco Supply Banner AD
  • Superior Driveline Banner AD
  • Shade Smith Banner Ad
1974 20’ Argosy Motorhome & 24’ Travel Trailer by Airstream
454 Original Engine
N/A
N/A
N/A
N/A
$80,000
$75,000 (Price Is Negotiable for Either or Both Units)
Share this classified
We purchased this Argosy motorhome in 2002 in Fort Collins, Colorado.  We traveled and camped in the motorhome for about 15 years, towing our 24’ trailer behind for my in-laws. The motorhome has been parked in our shop since 2018 undergoing renovations which were completed in 2022.  Workshop manual, original owner manual, and original chassis manuals included.
Motorhome Info:
  • Miles: 115,000
  • Engine Size: 454
  • Engine rebuild details: Original Engine
  • Chassis details: P30 Chevrolet Chassis
  • Generator Details: N/A (portable Honda 2000-watt)
Details for vintage MH restoration:
  • Paint stripped and aluminum polished; panel patch, rear curbside
  • New clearance and tail lights, new break away, and 7 wire plugs
  • Front shocks and steering damper
  • Two new 6-volt batteries (house), wet cell
  • One new 12-volt coach engine battery, well cell
  • 40-amp converter
  • New interior LED lighting
  • Newer laminate counters
  • Wheel bearings packed
  • New window and door seals
  • New window screens
  • New bed frame pullout
  • New decking (subfloor) not including bath/shower area
  • New core-tech laminate flooring
  • Original PEX water plumbing
  • New water pump
  • New Attwood water heater
  • Refurbished furnace
  • Partial new interior walls in aluminum
  • New faucets, original sinks
  • New 12v wiring and switches
  • New LED lighting for all interior lights
  • New couch cushions and upholstery
  • New driver, passenger, and spare seats and belts
  • Dash redone
  • Zip Dee awning (brown)
  • Two new fantastic fans
  • Road King TV antenna
  • 30 amp solar
  • New batteries
  • New tires (purchased in 2019, no miles on tires)
  • New upholstery
  • New flooring
  • New fridge vent
  • Two new 160-watt solar panels
  • Fresh white paint on the roof
Trailer Info
Original:
  • Stove: Four-burner (Magic Chef)
  • Fridge (no 12-volt needed)
Improvements:
  • Polished exterior (all paint stripped)
  • Roadside rear panel—some damage from awning
  • All clearance, tail, reverse lights, LEDs
  • LED breakaway switch/7-way plug with charge line
  • Wheel bearings serviced
  • Two new axels 2015, new brakes, new shocks
  • New aluminum wheels
  • 2022 Michelin Defender Tires LTX 23575 R15
  • Centramatic balancers on each wheel
  • Window and door seals original
  • Window screens replaced as needed
  • Original floor deck in good shape (replaced in rear battery area)
  • New 30 gal. grey tank and valves
  • Original black tank valve rebuilt
  • Click floor in 12x12 tile
  • New toilet and deck
  • New PEX pipe throughout
  • New water pump with lighted switch
  • New water heater (gas/electric)
  • New furnace
  • Replaced LP lines and valves as needed
  • Two polished aluminum 30-pound tanks (certified)
  • New 24” TV and DVD player
  • New radio/CD/Speakers
  • Two new 27 group batteries deep cycle flooded
  • New 12-volt wire and fuse panel
  • Two newer fantastic fans with rain sensors
  • Interior LED lights
  • Newer upholstery
  • Solar 200 watts charge controller
  • Intelli power 40 amps
  • Custom box for a seven-way plug to test/run lights with no truck (using house battery)
  • New drawers by the fridge (very deep)
  • Flag holder brackets (three flag poles)
  • Flag holder/chain organizer
  • Power front jack
  • Large level for easy setup
  • Black belly pan and trim
  • Deadbolt installed
  • Custom rock guards to cover clear wrap-around windows
  • See-through center rock guard makes into a table on propane tanks
  • Slight hail damage on the roof
  • Original owner’s Manual
  • See Level II tank monitor
