Author Topic: Remote Ether Injector  (Read 8157 times)
Offline Scott & Heather
  • MCI-9 & MCI-102
    • Fresh Day Music
« Reply #15 on: March 14, 2018, 08:46:39 AM »
I don’t think the debate should be whether ether is safe or not. I’ve used it a bajillion times without issue. But honestly, with straight 40w oil, should we really torture our engines with a couple of dry piston strokes before that thick as molasses oil starts flowing when it’s cold out? I think not. Do the engine a favor and just get a heater.
Check out this awesome demonstration of oil flow in the cold....and imagine your 40wt flowing ever slower!!!
https://youtu.be/tYkg0oDUXs8
Offline dtcerrato
Re: Remote Ether Injector
« Reply #16 on: March 14, 2018, 06:57:46 PM »
Forgot to mention we also are equipped with the 2000 watt Jimmy Heet block heater, it's nice to have choices & alternatives. :-)
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Offline chessie4905
« Reply #17 on: March 15, 2018, 03:43:37 AM »
May be simpler to update ether injector to current version.
« Reply #18 on: March 15, 2018, 08:23:19 AM »
If you don't want to install an electric block heater, then get a 500w halogen light and the night before you're going to start the engine, place the light below the oil pan shinning on the oil pan. It will heat the engine sufficiently to make engine starting more friendly. Good luck, TomC
Offline chessie4905
« Reply #19 on: March 15, 2018, 11:31:36 AM »
Sounds like he doesn't have electricity where the coach is kept.
Offline eagle19952
« Reply #20 on: March 15, 2018, 01:14:37 PM »
weed burner and 12-16 feet of 4" stovepipe, and a 90.
bottle of propane.
5 minutes (normally)
  • MCI-9 & MCI-102
    • Fresh Day Music
« Reply #21 on: March 15, 2018, 04:23:08 PM »
I used a heat gun pointed at the oil pan for 5 hours and coach started right up at 10°F
Offline Jim Eh.
  • Excess in moderation
« Reply #22 on: March 15, 2018, 04:37:08 PM »
Ditto. In the very least to ensure a correctly metered application.
Jim Eh.
1996 MC12
6V92TA / HT741D
Winnipeg, MB.
Offline sledhead
« Reply #23 on: March 16, 2018, 05:22:25 AM »
I put a kat 300 watt magnetic heater and it works great and is easy to use
here is a 200 watt one
https://www.etrailer.com/Vehicle-Heaters/Kats-Heaters/KH1153.html
dave
dave , karen
