Author Topic: VS overdrive  (Read 1578 times)
Offline treeplanter
  • the grey ghost,1971 GMC 5305A
VS overdrive
« on: May 01, 2020, 10:31:03 AM »
Our fishbowl has the VS transmission, modified by original owner. It has a overdrive switch on dash my question is what is the transmission doing when in overdrive mode?
Timothy
Offline Utahclaimjumper
Re: VS overdrive
« Reply #1 on: May 01, 2020, 02:06:41 PM »
 It goes to a higher gear ratio that allows the engine to spin at a lower RPM while the coach is traveling faster..>>>Dan
Utclmjmpr  (rufcmpn)
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
Re: VS overdrive
« Reply #2 on: May 01, 2020, 02:07:00 PM »
Double post.>>>D
Utclmjmpr  (rufcmpn)
Cedar City, Ut.
 72 VW Baja towed
Offline buswarrior
Re: VS overdrive
« Reply #3 on: May 01, 2020, 02:10:58 PM »
That's all the VS had: one to get it going, one to keep it going.
Direct and overdrive.
Previous owner likely rigged manual control so driver made the decision, not the machine, in hilly terrain.
Happy coaching!
Buswarrior
Re: VS overdrive
« Reply #4 on: May 01, 2020, 02:15:37 PM »
 For years I had a VS-8  first,,, second,,, overdrive...>>>Dan  ( By switching to a 5:55 rear end I had a three speed transmission that would pull hills,,,somewhat,,,,most of the time.>>>D
Utclmjmpr  (rufcmpn)
Cedar City, Ut.
 72 VW Baja towed
Offline buswarrior
Re: VS overdrive
« Reply #5 on: May 01, 2020, 02:28:52 PM »
Apologies, hydraulic and lock-up don't work their way into catchy phrases.
Starts in hydraulic direct, locks in direct, shifts to overdrive.
Happy coaching!
Buswarrior
Offline Bill Gerrie
Re: VS overdrive
« Reply #6 on: May 01, 2020, 06:59:13 PM »
The switch is to allow the driver to downshift the overdrive when he wants to due to a hill instead of waiting for the transmission to do it.
Re: VS overdrive
« Reply #7 on: May 03, 2020, 09:17:21 AM »
Something to consider-I looked hard to find a bus with the V730. With 4.56 rears and 11R-24.5, my 60mph cruise is 1900. My shifter is R-N-3-2-1. I can hold in second lockup, and if I pull it down to 1st can get torque converter lockup as low as 20mph. Going up long hills, I sometimes throttle back (especially when hot) in first and go up the hill at 32mph at 2100rpm. The V730 is an HT740 without 1st gear. Can still get parts for the transmission too. Good Luck, TomC
