Author Topic: Interior walls?  (Read 12762 times)
Offline grantgoold
Re: Interior walls?
« Reply #15 on: November 11, 2008, 06:06:53 PM »
Jack, thanks for the pictures. It has got me thinking about how to make the work and keep the wall thickness to an acceptable minimum. Now, can you describe how you keep the door closed and what about the door moving or "slapping" when driving? Do you also have a track on the floor?
Grant
Grant Goold
1984 MCI 9
Way in Over My Head!
Citrus Heights, California
Blacksheep
Re: Interior walls?
« Reply #16 on: November 11, 2008, 06:27:27 PM »
It took me a while but I found a picture showing my wall studs and pocket door while it was being made prior to laminate covering. Had to make sure it worked first! Anyway, you cant see the top track but you can plainly see the bottom extended drawer guide! Since this picture was taken, there was a 3/4 inch plywood wall up against (not touching) the door forming the pocket and that would be the start of my cabinetry in the kitchen.
Ace
Blacksheep
Re: Interior walls?
« Reply #17 on: November 11, 2008, 06:31:34 PM »
Here is another pic a little further done. The pocket door actually is behind the refrigerator on the right!
Ace
Offline grantgoold
Re: Interior walls?
« Reply #18 on: November 11, 2008, 06:54:00 PM »
Ace, thanks for the pictures!
I was hoping to see if anyone has used steel studs that are smaller than the 2x4? I want to save as many inches as possible and with a 3/8 or 1/2 exterior panel on each wall I think I can save nearly 6 inches of wasted wall space.
Anyone used smaller steel studs?
Grant Goold
1984 MCI 9
Offline wvanative
Re: Interior walls?
« Reply #19 on: November 11, 2008, 07:06:57 PM »
Hi Grant,
I agree with Brian Elfert. Why use wood at all? Metal studs are STRAIGHT and stay STRAIGHT. They are as easy, or easier, to work with as wood and did I mention that they stay STRAIGHT. Good luck with whatever you decide to use.
Sam 4106
Sam, did you have any problem with the steel studs attaching to the top plate where the roof has a curve in it going toward the wall?
Dean
Dean Hamilton Villa Grove, IL East Central IL. Near Champaign
Still Dreaming and planning
Offline paulcjhastings
Re: Interior walls?
« Reply #20 on: November 11, 2008, 07:08:44 PM »
I haven't seen any mention of using steel tubing, you can buy it in just about any size, shape, or gauge. No worries about taking up a bunch of space using steel or wood studs.
Paul Hastings
1993 Setra 215 w/ Detroit Series 60 & Allison HT748
Belle Plaine, MN
612-987-6021cel
makemineatwostroke
Re: Interior walls?
« Reply #21 on: November 11, 2008, 07:50:25 PM »
Paul; my last BlueBird had tubing for wall framing with foam between the plywood the only problem I ever had was my wife wanting to redo a wall in the bathroom it is almost impossible to remodel with steel tubing welded in place
have a great evening
Offline JackConrad
  • Orange Blossom Special II
Re: Interior walls?
« Reply #22 on: November 12, 2008, 05:05:28 AM »
Thanks Grant
No track on the floor, only a guide.  We originally tried a barrel catch that the door seated into when open, but it did not always hold. We then installed a barrel catch near the ceiling that goes into a hole in the piece of oak trim on the ceiling. This catch holds the door in both the open and closed position (using different holes in the ceiling trim).  If you open or enlarge the photo of the door , you can see the barrel bolt in the top right hand corner of the door. Jack
Offline Sam 4106
Re: Interior walls?
« Reply #23 on: November 12, 2008, 08:10:43 AM »
Hi wvnative,
Forming the plate to fit the contour of the ceiling if relatively easy. Use an aviation snips to cut the sides of the plate to form any curves then tack weld the overlaping metal at the cuts. By making your cuts close together you can form a very tight curve. Clamp or tack weld one side, after you are satisfied with the fit, then clamp the piece to a flat surface before tack welding the other side. Otherwise, you may have a compound curve in the piece. It helps that I have many years of metalworking experience, but if you are careful, you can do a good job. I placed my 1 1/2" studs 12" apart and after I had my electrical boxes and wiring in I filled the cavities with block foam insulation for sound deadening and full backing for the 1/4" luan plywood I used behind the wall paper.
Paul Hastings' idea of using square or rectangular tubing is also a good suggestion. Your choice.
Good luck, Sam 4106
Offline belfert
Re: Interior walls?
« Reply #24 on: November 12, 2008, 10:12:32 AM »
I used 1 5/8" steel studs around my bunks and 2 1/2" steel studs for the bathroom walls.  No 2x4 (really 3 1/2") studs used here.
Offline grantgoold
Re: Interior walls?
« Reply #25 on: November 13, 2008, 05:14:22 PM »
I think I am going to go with the 1.5 inch steel studs and 1/4 plywood. Thanks for all the help and suggestions. I think I may also try the slider door that doesn't require a true pocket door frame, again saving valuable space. I hope this gives the impression of a much larger space.
Grant
Grant Goold
1984 MCI 9
Offline Jerry32
Re: Interior walls?
« Reply #26 on: November 14, 2008, 07:45:08 PM »
I justused 3/4" plywood for walls and I too built a pocket door with no pocket.  Jerry
1988 MCI 102A3 8V92TA 740
