Author Topic: is mci the only one with cooling issues??????  (Read 2957 times)
Offline mccarlk
  • 1967 mci 5 8v71 auto
« on: November 19, 2008, 05:41:33 PM »
hi after reading numerous posts, i have seen that mci has the most heating issues, if thats so, could you not install a side mount rad, and a fan drive like in a a prevost? any ideas?????
treat every day like is your last, just make sure you dont spend all your money,in case its not!!!!!!!!!!!!!!
Offline grantgoold
Re: is mci the only one with cooling issues??????
« Reply #1 on: November 19, 2008, 05:44:58 PM »
I can tell you that I completely rebuilt the shrouds around the radiators on my MCI9. I made sure that I made the shourd with heavy rubber that always stays in place. I saw a 10-15 degree drop in temperature after the rebuild. It also made sure the squirrel cage system was and is maintained.
I have no cooling issues here in California.
Grant
Grant Goold
1984 MCI 9
Way in Over My Head!
Citrus Heights, California
Offline RJ
  • VantarĂ© Conversion "Miss Vivian"
« Reply #2 on: November 19, 2008, 06:55:53 PM »
Anything's possible if you throw enough $$$$ at it.
Offline John316
« Reply #3 on: November 19, 2008, 07:11:51 PM »
We don't have cooling issues, with our Dl3. We do have radiators that are in great condition, if that makes any difference. Earlier this year we drove up the Fraser river canyon, in Canada, and the bus did great (not to mention that we have done most of the steep grades out West in the mountains). It does slow down, but it doesn't over heat...Yet. ;)
Watch, I will say this, and next trip in the summer we will overheat... ::) ;D
HTH
God bless,
makemineatwostroke
« Reply #4 on: November 19, 2008, 07:20:57 PM »
John316;FWIW you have a s S60 the turbo takes the heat out and the 2 strokes depend on water to take the heat out
have a great evening
Offline John316
« Reply #5 on: November 19, 2008, 07:32:58 PM »
mma2s, Thanks for the correction. I know that our S60 is a lot different from the two strokes. I just didn't know how different. ;) Thanks. (now you know why I post here, I need a lot of help ;D)
In that case, you all with two strokes should change to a S60... JK of course. ;D ;D ;D
God bless,
Offline Melbo
  • MC8 under construction
« Reply #6 on: November 19, 2008, 07:48:18 PM »
I have an MCI and an L10 because I tired of the heat issues and needed to rebuild or replace so there are options
Melbo
Offline jjrbus
  • MCI5C/N Ft Myers FL
« Reply #7 on: November 20, 2008, 01:48:59 AM »
I have a 79 MCI 6V71 non turbo. I changed the thermostats to get it to run warmer!! I know my bus has the larger MCI9 radiators in it with no shutters. My cooling system filler cap had lost its seal and the system was unpressurized, which I fixed.  It is possible for them to run without heat issues.  Jim
