June 23, 2018, 10:04:43 PM
Author Topic: walking on roof....  (Read 7043 times)
Offline turbobrat930
walking on roof....
« on: November 20, 2008, 12:42:09 AM »
Ok, Another newbee question here... I have read about 50 pages worth of posts so far, and getting tired...I need to hit the sack for the night, but one question before I go...
When we are at the racetrack and are using my buddy's Warnderlodge, we get up on the roof, sit in some camping chairs, and watch part of the race from there. Great platform for taking pictures. The Wanderlodge has diamond plating on the exterior of the roof, and I believe came from the factory that way. Is is very sturdy.
Here is my question...Is one bus better than another when it comes to using the roof as I speak of? Is an Eagle better than a MCI, or prevost better than all? I just dont want to be looking for one make of bus, because I like the look, price, location, etc...and then find out later that I should have bought a different bus that had better roof bracing, etc
Thanks in advance...
Brad
« Last Edit: November 20, 2008, 12:44:01 AM by turbobrat930 »
Offline JackConrad
  • Orange Blossom Special II
  • Global Moderator
Re: walking on roof....
« Reply #1 on: November 20, 2008, 04:56:27 AM »
   I don't think any brand of bus was designd to have people walking around on the roof.  Most people that use the roof as an observation deck, build a platform on top of the roof.
   As far as 1 person getting on the roof to install vents, antennas, etc. bo problem as long as you keep your weight mostly on the rivet lines (above framing members). We had our MC-8 ceiling sprayfoamed with 2" of foam. I can walk around anyplace on the roof and not feel any "give", but that is just 1 person.  I would not plan to use my roof as an observation platform.  JMO, YMMV  Jack
« Reply #2 on: November 20, 2008, 05:19:42 AM »
Jack, thanks for the reply. After I posted, I located one post speaking of just that..a platform. I think that is what I will do, and then possibly have a access hatch from the inside with a fold up ladder to gain access to the roof. A ladder on the back of a Blue Bird does not look out of place... but IMHO...on the back of a newer style cap on a MCI, Eagle, etc... it would look WAY out of place..
Offline HighTechRedneck
  • Global Moderator
  • BCM Webmaster
    • Bus Conversion Magazine
« Reply #3 on: November 20, 2008, 07:33:03 AM »
I agree the interior ladder would look much "classier".  I have read of several using the rear emergency roof hatch and adding the fold down ladder.  I remember a very detailed thread on observations decks sometime in the last year here.  That may be the one you found, but if the one you read didn't have a lot of detail on how they built it, then keep searcing because there is one with a lot of "how I did it" content.
Offline JackConrad
  • Global Moderator
« Reply #4 on: November 20, 2008, 11:13:29 AM »
The ones I have seen made a frame that stood off the roof a few inches and attached to the roof framing members with small post. The deck was covered with aluminum diamond plate. In addition to giving you an observation platform, it helps block the radianat heat from getting to the actual bus roof (similar to the Saudi MCIs).  This helps to keep the bus cooler.  Jack
Offline DebDav
« Reply #5 on: November 20, 2008, 11:27:18 AM »
I am still in the structural stage.
I have installed a 24" X 24" boat hatch in the roof.  I am going to build  a raised platform, attached to the structural  roof members.  I have seen someone (maybe Gumpy?) that made a unique, folding ladder that pivoted up and folded flat into the ceiling.
Also remember to provide some side fence materials.  Either folding or with mounts that can be filled with fencing when parked.
Offline JohnEd
« Reply #6 on: November 20, 2008, 11:46:03 AM »
It is Gumpy.  His ladder is a work of art and folds to about a 4 inch thickness when it is stowed against the ceiling.  If you are just getting started, Gumpy's site is a must read.  Their are others of similar merit but none his equal IMHO.
HTH,
« Reply #7 on: November 20, 2008, 12:20:00 PM »
HTH,
In all the old posts... the link to Gumpy's site no longer works.. maybe he will post up and give an updated link...  In the posts that I read, the Gumpy ladder and his hatch are held in high regard... cant wait to see pictures... Brad
Offline white-eagle
« Reply #8 on: November 20, 2008, 12:29:18 PM »
HTH,
Please...  his head is big enough as it is.  and his site seems to be down. :(  networking issue probably.  ::) ::)
We put a deck in between the A/C units.  about 1 1/2" alum angle run down both sides and center. tapped so that we could bolt down 3/4" plywood, painted, which is less slippery than diamond plate.  also easier to cut out the vents, skylights, etc.  We didn't want a big hole in the ceiling, so we use an outside folding ladder when necessary.  also keeps others off the roof easier than a permanant ladder on the back which would indeed look ugly.
We mounted our solar panels, antennas and satellite Internet to it, so they can be re-arranged or replaced without redrilling the bus roof.
we haven't gone to nascar or formula 1 lately, so haven't tried it for sitting yet.
it's also a little icey right now.  >:( >:(
« Last Edit: November 20, 2008, 12:31:26 PM by manasst »
Tom
Offline jjrbus
  • MCI5C/N Ft Myers FL
« Reply #9 on: November 20, 2008, 02:17:07 PM »
Many folding ladders have been done, it is time for an elevator. That will get you the BCM centerfold spot.
cody
« Reply #10 on: November 20, 2008, 02:19:08 PM »
An elevator would be great but a catapult would be more fun lol.
« Reply #11 on: November 20, 2008, 02:29:11 PM »
An elevator?? LOL...now that would be something special... make it look like a old style phone booth..so when it pops out of the roof...you would arrive in style..
I do like the idea of a sprial staircase hidden in a closet... would be kinda unique...  ideas, ideas, ideas!!!
Offline Len Silva
    • Leonard Studio
« Reply #12 on: November 20, 2008, 02:30:57 PM »
Beam me up, Scotty!
Offline Len Silva
    • Leonard Studio
« Reply #13 on: November 20, 2008, 02:33:10 PM »
Of course, if you are going to do an elevator, you might as well take the kitchen and bathroom up with you.
Offline WEC4104
« Reply #14 on: November 20, 2008, 02:42:59 PM »
Forget the slide-outs, who's going to be the first with a slide-up?
