Author Topic: where do I get a speed pick up for king cruise on a 4104 with a 6-71  (Read 2906 times)
Offline 4104bigred
  • Jr. Member
help I'm trying to find a speed pickup on our 58 4104 with a 6-71
thanks in advance
chris
Offline 4104bigred
  • Jr. Member
Re: where do I get a speed pick up for king cruise on a 4104 with a 6-71
« Reply #1 on: June 27, 2006, 05:44:22 AM »
Maybe I should clarify this post.
I have a king crusie and want to install it in our 4104. so the cruise needs to be connected to a speed sensor and someone out here must know where i can hook this wire to
chris
Dallas
« Reply #2 on: June 27, 2006, 06:10:46 AM »
Chris,
Many people have used magnetic sensors that attach to the left front wheel and read from four bolts drilled into the brake drum.
You could probably do a search on Google for either "King Cruise" or for magnetic speed sensors.
Sorry I wasn't more help. I don't have fancy stuff like a cruise control or enough power to worry about it. I just plop a brick on the foot pedal and let it go.
0-60 in 15minutes
0-96 in 50 minutes, (Ticket and points on my license to prove it!), as long as there is a good downhill and a tailwind. If the old girl sees an overpass, she gets scared and slows right back down to 65.
Dalllas
« Reply #3 on: June 27, 2006, 06:33:55 AM »
Have you tried contacting King Cruise directly with your question?  www.cruisecontrolking.com is the website.
Brian Elfert
