Author Topic: Bathroom exhaust gurus?  (Read 17252 times)
Blacksheep
Re: Bathroom exhaust gurus?
« Reply #15 on: January 12, 2009, 07:16:37 PM »
I just would like to know why it HAS to be thru the roof? Mine goes thru the floor and it has worked great with NO smell at any time! If mine works, why does it HAVE to go thru the roof?
Just curious!
Ace
Offline pvcces
« Reply #16 on: January 12, 2009, 08:48:44 PM »
Brian, reversing the polarity on the motor will probably be all it takes to reverse the fan.
For what it's worth.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
Offline Lin
  • 1965 MC-5a
« Reply #17 on: January 12, 2009, 09:02:01 PM »
That RV 360 vent cap looks interesting.  It supposedly turns with the direction of the wind.  One would think that it would have the whole toward the back when heading down the road.  But just in case something weird is going on, maybe you could fix it in place.  I don't think your real concern is when docked anyway.
Offline Dreamscape
  • Dreamscape
  • Global Moderator
« Reply #18 on: January 13, 2009, 05:18:26 AM »
I had an RV 360 vent cap, it lasted for five years then the plastic swivel broke. It's on the highway somewhere between Abilene and Eisenhower State Park. ::)
They look neat but I didn't like the fact that it didn't last very long. I just installed a 1 1/2" pvc el in it's place.
FWIW,
Offline Ednj
  • Ed & Sue Skiba
« Reply #19 on: January 13, 2009, 06:16:19 AM »
MCI-9
Sussex county, Delaware.
« Reply #20 on: January 13, 2009, 06:39:41 AM »
this is confusing to me I thought Grant was asking about something to remove the moister and the smell from the bathroom not venting the tank, then Belfert made the statement that his Fantastic Fan doesn't work and later he tells us he has one of the small RV power vents, help the guy don't confuse him        good luck
Offline belfert
« Reply #21 on: January 13, 2009, 06:46:19 AM »
I don't have any sort of power vent for my plumbing vent.  I do have a Fantastic Vent in my bathroom.
« Reply #22 on: January 13, 2009, 07:09:45 AM »
sorry Belfert It didn't come out right I thought you talking about one the vents fans in the pipe, I love the Fansatic Fans    good luck
Offline akbusguy2000
« Reply #23 on: January 13, 2009, 11:40:47 AM »
After a couple of other bathroom vents that proved unsatisfactory, I finally got the right one.  It's a quality product and works fine.  I mounted the remote switch on the wall where I can reach it from the sitting position.  I turn it on when I sit down, and off before I flush.  Works as the name applies, "fantastic."
 http://www.rvvent.com/b2000r.htm
tg
Offline JohnEd
« Reply #24 on: January 13, 2009, 11:55:34 AM »
"IF" I could get the same air volume exhausted and take the air from the top of the room with a "thru the floor vent" "thru the wall", there is no way in hell I would punch a hole in my roof.  No way!  Due to the ducting needed and their inherent resistance to air flow, the fan would NEED to be a squirrel cage to get any flow/volume.  A speed control and thermostat would be ideal.  No need for a rain sensor....DUH ::)
Consider that with a squirrel cage you could locate the fan in the bay.  Important option, maybe.
Of course my Fantastic fan is also a skylight and a source of "cheering" ;D light.  I guess you could do that with a thru the floor vent but you would have to use a lot mirrors. ???
HTH ;D ;D
cody
« Reply #25 on: January 13, 2009, 11:57:23 AM »
We opted for the maxxair vent instead of the fantastic vent for a couple of reasons, it already has a shroud that is weather proof but the primary reason is that it has 12 inch fan mounted outside and away from the ceiling opening, it's fully reversable with 3 speeds and quite powerfull, ours set blowing out on low, actually creates a breeze coming in the windows.all that is required besides a 12 volt line to it is a standard rv ceiling vent, the kind that a person would find in most travel trailers or campers, the shroud mounts around it and over it so the vent can be left open in the rain or traveling down the road with or without the fan running, a thrmostatically controled unit is also available, either way both fans are good, but the maxxair unit better suited our needs.      http://www.maxxair.com/Products/Turbo-Maxx.aspx
Offline JohnEd
« Reply #26 on: January 13, 2009, 12:12:07 PM »
Cody,
I think the max air would be superior to the Fantastic Fan....if the Max had anywhere near the air flow.  My FF makes a lot of noise on hi but I seldom need that speed...still, if the Max has a quieter fan located outside that is a real advantage.  On low, my FF is whisper quiet.
Good point you made.
Offline FloridaCliff
  • "The Mighty GMC"
« Reply #27 on: January 13, 2009, 12:19:01 PM »
Grant,
I ended using a hi volume house type exhaust fan that is vented down, works great.
Like you I wanted to minimize my ceiling holes.
I may, before I am done, vent it out the side, even though the down pipe works great.
I made a space between the back of my bathroom and shower where all the pipes, vents run.
By pulling out the wall closet(four screws in back corners), behind and above the toilet(built as one piece, including front)I can access everything for those two spaces.
On the vent pipe as others were mentioning:  I tried several types of venting, RV360, cut pipe, but the one that works flawlessly was by putting a PVC tee facing fore-aft and reducing it from 1 1/2 to 3/4 on the front facing end.  The venturi effect absolutely stopped any odors from entering the cabin while underway.  YMMV
Cliff
Mark Twain
cody
« Reply #28 on: January 13, 2009, 12:25:21 PM »
John if you check the spec sheet you'll find the maxxair has a lot more air flow than the fantastic vent, the specs for the fantastic vent according to their website is 478, 653, and 920, at low, medium and high, for the maxxair they are 500, 680, and 982 for low, medium and high, I wasn't sure which vent you were refering to so I used the 8000 series, that appeared to be the most powerfull, the maxxair I used was the turbomaxx, thats the one I listed and the one I have, like I said either one would be great but the maxxair moves more air according to the spec sheet, the decible rating for the maxxair wasn't listed but I do know that mine can't be heard on low and is whisper quiet on medium and very reasonable on high.
Offline gus
« Reply #29 on: January 13, 2009, 12:49:25 PM »
Boogie,
There is always the possibility that more than one method of venting works well just like there is usually more than one way to do something.
