All this leads up to the $64,000 question. I can get Bandag retreads made on a nice set of Michelin 315/80R22.5 casings (from a coach) in any tread pattern I'd like -- they have at least three M&S patterns that would work. They'd cost me about $265 per tire before taxes and mounting. So given the weight on our axle (24,000 lbs) and the way we use our bus (mostly keeping to 60mph or below, except when on Red Cross assignment, where we "wick it up" to 65-68 for maybe eight hours a day, five to ten days per year), what says the group here about running Bandags on the drive axle? And yes, I know I am opening a can of worms, and that we've had similar discussions here in the past.More importantly, is (or has) anyone here run retreads on their bus, and, if so, what was/is your experience with them?
I am confused by your comment on rotating the tires; rotate the drivers where? They are drivers they stay there for life but if you must rotate them; change the inside left to outside right and outside left to inside right and so on. The tires are now rotated from crown to shoulder and inner to outer and still turning the same direction.
