Author Topic: How Tall is Your Bus?  (Read 8161 times)
Offline Singing Land Cruiser
  • Michael & Christi Hargis
  • Found another Bus= '77 AMGeneral 10240B; 8V-71
    • michaelhargis.com
« on: April 18, 2009, 03:15:09 PM »
I was looking up Bus Intel. on the web and came across a blog about a bus that was trapped with in a city due to Low Bridges. I thought to myself, "How tall is Mrs. Jones? (Our MCI) So at 1:45 am I'm out the door armed with a flashlight and a tape. After stumbling around in the dark I came up with 11'.3". Then thought "Air Bags". Got to start it up. Better wait till morning. So I don't know!?!
Do You Know How Tall Your Bus Is? Post your bus height along with the Make, model & Year. Don't forget the roof airs! ::) All the Best, M&C
Entertainers/BUSNUTS
Master Mason, Noble Shriner
Offline JackConrad
  • Orange Blossom Special II
  • Global Moderator
Re: How Tall is Your Bus?
« Reply #1 on: April 18, 2009, 03:43:26 PM »
Our 73 MC-8 has an 8" roof raise.  OEM height was 10'10' plus 8" roof raise makes it 11'6". Tallest non movable obstruction on roof (flexible antennas don't count) is the satellite antenna in travel position which adds an additional 8 1/2" for a total of 12' 2 1/2".  We figure a minimum clearance of at least 12'6".  We can gain about 3" by dumping the air in the air bags.  Jack
Offline mikelutestanski
  • Mikes Metal Mistress
« Reply #2 on: April 18, 2009, 03:46:41 PM »
Hello:
   About so tall does not cut it.. You had better know exactly how tall your bus is and observe the signage so that you can avoid knocking off whatever is on the roof... or the roof itself...
   My 72 7 is within a quarter inch of 12 feet even...
     And if I see a bridge and no signage that tells me how high the bridge is I get nervous and stop to check it out..
    Now let me tell you a little story...
   I had a dream one night about the bus and a bridge and the very next day we missed our turn and continued on until in the distance I saw the bridge..   and nothing to tlll me how high it was..  An old RR bridge on route 40 east of Dunnellon FL.   SO as we approached the bridge I slowed way down and finally stopped a ways back.   I stopped traffic and we looked at the bridge until we finally saw some old faded paint that said 14 feet 2 inches.   Once that was established we could safely pass through which we did and turned around and made the proper turn to get to our destination.  Our future home was just up the road and now I know all the roads and can advise any bus people in the area
    Most places if the bridges are around 12 feet they usually mark the roads leading up to that area because disasters are not pleasant for anyone involved including the local townsfolk.
    CAse in point a well marked brige just off rte 81 north of Syracuse ny . The road was a connector to a northern suberb Liverpool and is very well travelled.   The bridge was 12 foot 2 inches and signs were on all roads including route 81 .
    Well at least once per year and usally twice a tractor trailer would try it and what a mess..   So pay attention to your surroundings.
    So FWIW you need to pay attention and know where you can go.
    THe new GPS gizmos have a trucker setting which will supposidly help you avoid  low bridges...
   SO you have choices..
   REgards and happy bussin   mike
  1972 MCI 7
  L10 Cummins  B400R  4.625R
Blacksheep
« Reply #3 on: April 18, 2009, 04:36:25 PM »
Our bus which is a 92 H3-40 has low profile coleman roof a/c's and at one time was the tallest item on the roof making the height when aired completely up a whopping 13'2" but have since installed a king dome satellite dome which also is the low profile but just a tad higher than the a/c's making the overall height when aired up a whopping 13'4".
I think Cliff with his GMC is even higher than that!
Ace
Offline RTS/Daytona
  • Pete RTS/Daytona ->'89 TMC 35' 102" 6V92TA 4:10
    • BUS CONVERSION PARTS FOR SALE / PROJECTS
« Reply #4 on: April 18, 2009, 04:50:04 PM »
OEM - GMC and TMC RTS Transit buses  - 9'11'  + 10" Dometic low profile penguin 15,000 btu A/C units - Total 10' 9"
Offline Ed Brenner
« Reply #5 on: April 18, 2009, 04:56:08 PM »
   77 Eagle 05 raised roof, top of ac units 12' 6"
 I'll follow Ace  ;D
Ed
Ed Brenner
77 Eagle 05  Murrells inlet, SC
 " While We're At It " A Busnut's most costly Phrase !!
Offline belfert
« Reply #6 on: April 18, 2009, 05:29:07 PM »
12' 9" to the top of the roof airs.  Torsion suspension so need for air when measuring.
I slowed to a crawl last fall when going under a bridge marked around 13' since it has grades on either side.
Offline jackhartjr
  • Beauty is in the eye of the beholder!
« Reply #7 on: April 18, 2009, 05:42:08 PM »
I will let you know when we get it on the road.
However with no air in the bags it is Exactly 10'-6".  How do I know this...the dropdeck I brought it home on was 3 feet.  When we put it on the trailer we measured it again, Exactly 13'-6"!
Jack
Jack Hart, CDS
8V71 Detroit
4 speed Spicer Trannsmission
Offline Melbo
  • MC8 under construction
« Reply #8 on: April 18, 2009, 06:09:37 PM »
We have an MCI 8 with roof raise ( by PO so exact # unknown ) with two roof top airs and a KingDome satellite.
We are 12' 9" when aired up.
Going through Mobile Alabama on the way home from Jack's we set off the alarms approaching a 12' tunnel.  The red lights came on so I stopped and pretty soon the Alabama DOT showed up -- we unhooked and changed direction ( took the truck ( bus ) route ).  The MAN from the dot laughed and said people ignore the alarm ( laser beam ) all the time and hit the tunnel. He pointed to the top where you could see the marks from the impacts ( yes way more than one ). As noted previously the height marking was sort of obscure but the alarm was very helpful. Another disaster avoided.
Melbo
Offline Gary '79 5C
« Reply #9 on: April 18, 2009, 06:16:15 PM »
Gee and I thought I was being overly attentive when I picked up my bus in St. Louis. I would not pull out until I personnally measured (12' 4") as I wanted to take no one's approximation.
I for a long time had a 3x5 card with checklist items on the dash, 12' 4'  was one of them.
Ocean City, NJ
Offline WEC4104
« Reply #10 on: April 18, 2009, 06:22:57 PM »
My 4104 with roof air is 11' 3", but I consider it 11' 6" based on air bag inflation and other weight variables
Offline jmblake
  • Jason & Martha Blake
    • Creative Custom Cabinetry
« Reply #11 on: April 18, 2009, 06:48:44 PM »
Mine is a 81 MCI9 with a 8" roof raise and two 15,000 dometic airs and Iam 12'9" to the top of the airs. Jason
Offline JimW7
  • 1970 MC7
« Reply #12 on: April 18, 2009, 07:59:04 PM »
1970 MCI 7, 11'10" top of roof airs.
1970 MCI 7 serial # 8425
Offline FloridaCliff
  • "The Mighty GMC"
« Reply #13 on: April 18, 2009, 08:13:46 PM »
Ace
Ace,
I thought I was close to that number too!  But I am just finishing up a new Bus Barn addition of 20X50 for the "Ole girl" and  I finally took an actual measurement with her aired up and all, before I poured my slab.  The bus is 12' 6" at max height on the top of the rear air and the bottom of the trusses are 13"0.
So I will be looking up at you for sure!  ;D
Oh yeah, 1975 GMC 4905, raised 10".
Cliff
Mark Twain
Offline jackhartjr
« Reply #14 on: April 18, 2009, 08:35:30 PM »
Cliff, I know we talked about this before.
I think you said that you had the air conditioners where you could take them off pretty quick if you had to be towed on a Landoll.
What would your bus be with no air and the roof mounts off?
Jack
Jack Hart, CDS
8V71 Detroit
