June 23, 2018, 04:31:03 PM
Author Topic: Where to find really long heater hose?  (Read 5609 times)
Offline belfert
« on: April 23, 2009, 05:32:05 PM »
I have about a 6 or 8 foot long chunk of what looks like 1.5" or 2" heater hose going from one side of my engine to the other in a big loop.  It has a small pinhole leak in the middle of the hose where nothing could chafe it.
Any ideas where to get hose that long?  Everybody carries 3 foot sticks.  I can't even locate this hose in my parts manual to see if MCI sells it.  I'll have to call MCI in the morning.  My friend suggested a pipe to replace the bad section, but I worry another spot will start to leak if I don't replace the whole thing.
I still can't figure out why Dina saw fit to use the spot normally fitted with a block heater to run coolant out to the passenger heating system.
Offline gumpy
  • Some Assembly Required
  • Slightly modified 1982 MC9
    • bus.gumpydog.com
Re: Where to find really long heater hose?
« Reply #1 on: April 23, 2009, 05:35:59 PM »
Replace it with copper.
Or cut the leak out and put a piece of copper pipe in it.
Offline Marcus
  • Jr. Member
« Reply #2 on: April 23, 2009, 05:51:21 PM »
If you have a marine surplus close by they should have it. Ours does in Sarasota fl. Marc
Offline BG6
« Reply #3 on: April 23, 2009, 05:58:42 PM »
Try NAPA or some other "real" auto parts shop.
Offline belfert
« Reply #4 on: April 23, 2009, 06:22:52 PM »
I tried two NAPA stores that sell parts for heavy trucks already.  This type of hose seems to only be sold in three foot chunks.
Offline BG6
« Reply #5 on: April 23, 2009, 06:30:03 PM »
Maybe you can find out which company makes it, and find a distributor who handles the longer sections.
Airbag
« Reply #6 on: April 23, 2009, 06:35:30 PM »
McMaster Carr or Grainger or JC Whitney "just shots in the dark"
Offline Lin
  • 1965 MC-5a
« Reply #7 on: April 23, 2009, 06:50:41 PM »
An industrial hose company should have something that would work.
Offline belfert
« Reply #8 on: April 23, 2009, 07:00:48 PM »
I never would have thought of McMaster-Carr.  They do have hose in long lengths.
This should work I assume: http://www.mcmaster.com/#coolant-hose/=1ksbuj  Is the 212F going to be an issue?  The engine shouldn't be getting that hot anyhow.
Lin, I tried an industrial hose company last time I needed a 40" hose and I ended up with hose used for milking parlors.  It is rated for antifreeze and the proper temps so I bought it.  It is still going strong after two years.  I'll probably try the industrial hose place again before I order from McMaster-Carr.
Offline kyle4501
  • NEWELL in South Carolina
« Reply #9 on: April 23, 2009, 07:50:12 PM »
Any parts store is only as good as the employees that work there. I have yet to find a decent employee at any of the napa stores around here. Even when I provided the correct napa part number for a lower radiator hose (after they couldn't find it), they wanted to charge me the unit price per foot . . . . yep, 10x the actual cost. (For a minute there I thought I was dealing with a talking bird  :o )
Industrial supply houses are where I find the best service. . . .
I'd think the 212F rated hose wouldn't be enough to provide lasting durability.
Offline JohnEd
« Reply #10 on: April 23, 2009, 08:51:33 PM »
I agree with Kyle.  212 isn't enuff.  I think the worse problem is that auto and truck stuff is grease, oil and fuel resistant.   I am not saying dairy hose doesn't meet that environment criteria.....but I think that needs to be verified.
Offline buswarrior
  • '75 MC8 8V71 HT740
« Reply #11 on: April 23, 2009, 09:29:35 PM »
Use a short piece of metal pipe to tie two pieces of rubber pipe together to make your length?
I would look hard at the suggestion to make up a copper pipe to cover most of the distance and a couple of short pieces of straight stock rubber to attach the ends.
Offline belfert
« Reply #12 on: April 24, 2009, 04:33:58 AM »
The dairy hose is a seperate issue.  It was used to replace a smaller diameter hose that is around 39" long.  I didn't buy it before the saleman verified it was resistant to antifreeze and would meet the temp specs.  I don't know that diary hose would work a larger diameter anyhow.
Goodyear makes heater hose for trucks in long lengths, but the sizes are limited.  I need to figure out the exact size I need.
Offline belfert
« Reply #13 on: April 24, 2009, 04:36:00 AM »
Typical heater/radiator hose has a 260 degree or more rating so the McMaster-Carr stuff won't work.  I am going to look at the costs of doing copper instead of hose.
Offline dbenck
  • Jr. Member
« Reply #14 on: April 24, 2009, 04:54:12 AM »
Try Pirtek on the corner of University Ave. & Vandalia, St. Paul
