Author Topic: what is the best rv deep cycle battery? Trojan t-105?  (Read 97037 times)
Offline Oregonconversion
    • Somethingforever.com
Re: what is the best rv deep cycle battery? Trojan t-105?
« Reply #15 on: May 18, 2009, 10:22:37 AM »
I just talked to Zack at www.thesolar.biz about AGM batteries, and he recommended using these 2 volt 915AH batteries hooked in series.
He explained that hooking batteries up in parallel is not as efficient.
6 of these 2 volt batteries is quite expensive at around 2K, but if I only drain to 70% or less then they should last 8-10 years.
The big + is they are maintenance free.
Try, www.windsun.com you can find prices for different Agm brands of batteries along with the ratings    good luck
« Last Edit: May 18, 2009, 10:25:54 AM by Oregonconversion »
1977 MC8
8V92 HT740
Offline Bob Belter
  • Eagle 01 //Cummins M-11 Roadranger OD RTO1110
« Reply #16 on: May 18, 2009, 10:43:11 AM »
Ahoy, BusFolks,
I installed ten (10ea) Deka GC25 batteries in my -01 Eagle about six months ago.  I also installed a (2ea) Profill watering system which I got from:     Tom  RVPowerSupply.com  1 888 447 4552  at a good price.  Combo works just GREAT, with indeed a trivial task to squeeze the water bulbs a few strokes before each trip.  I had a previous AGM installation, and never got the stated AH performance.  As far as I am concerned, AGM stands for " Always Gonna Malinger".
Enjoy  /s/  Bob
« Reply #17 on: May 18, 2009, 11:48:18 AM »
Now I am thinking about switching to a 48 volt inverter and batteries! Oh my...
1977 MC8
8V92 HT740
Offline Damn Yankee
  • Jr. Member
  • Bob Shafer 1965 Mci-5A-6029 8v71 auto
« Reply #18 on: May 18, 2009, 01:38:56 PM »
There's a 24v Hi-Lo battery in my coach. Lots of power in 1 package. If you can find a core you can get it rebuilt for around $800.
 I know a couple of people that use them and are very happy.
Offline akroyaleagle
« Reply #19 on: May 18, 2009, 03:09:26 PM »
I started with 8 of the 12v 8D's. Died before 24 months. Went to 6 Trojan L-16 6volts, they were still going strong at 6 years. I last updated with 6 rolls-royce Surettes from Canada. They too are 6 volt and work great. Warranty in Rv applications is 8 years! I think they cost more now than when I got them from the distributor in Phoenix, but what doesn't.
http://www.solar-electric.com/batteries-surrette.html
I am hard on batteries. I check the water about once a year. Never have to add much. I have a household refrigerator and run my front roof air off the inverter when driving. I have a couple switch to couple the batteries to the 300 amp bus alternator.
I don't know much about birthing babies and electrical. But I do know what works for me over the past 15 years.
Joe Laird
'78 Eagle
Sioux Falls, South Dakota
Offline niles500
  • Niles500
  • ROSIE
« Reply #20 on: May 18, 2009, 03:15:07 PM »
Current dealer cost for Lifeline 4d AGM's is $315 plus shipping - so 8d's should be about $350 - knowing the cost might get you a better deal with a hungry dealer that direct ships and doesn't have to touch them - Trojan has AGM's - when I previously was going to use them I called around until I got a wholesale price - If you have a friend in Marine or RV business or a tax ID # and a commercial location you should get a decent wholesale price and you can Will call them and save shipping - They were less than half the cost of the cheapest price quoted for Lifelines - FWIW and HTH
(\__/)
(")_(")
- Niles
  • Gold Donor
« Reply #21 on: May 18, 2009, 03:23:45 PM »
Joe, don't  know what you paid for the Surettes but I check on 6 of the 830 amps 6 volts and they were 1100 dollars each and that was the best deal I found in AZ.Nice batteries but very expensive now.Became a no brainer for me after I did the math over 7 grand with shipping  that amount will buy you 15 sets of 6 from Costco or Sams even  lasting only 5 years per set that would give 75 years of batteries
« Last Edit: May 18, 2009, 03:43:36 PM by luvrbus »
« Reply #22 on: May 19, 2009, 06:24:11 AM »
Seems I paid about $1600 for the 6. The distributor and business licence is theway to go. I did both.
Mine are 595ah each.
Joe Laird
'78 Eagle
