June 24, 2018, 04:03:59 AM
Author Topic: Inverter Questions  (Read 5732 times)
Offline Zeroclearance
Re: Inverter Questions
« Reply #15 on: May 29, 2009, 03:42:12 PM »
Thanks Sean for the advice..   I am knee deep with my Delco 50 DN rebuild.   I have ordered a new updated Delco "long Life" stator assy.   To find out that Delco Remy has offered a "special" on factory rebuilt UPDATED 50 DN's.
Offline paul102a3
« Reply #16 on: May 29, 2009, 07:22:19 PM »
Sean, Can you suggest an item number for a solenoid from Grainer. I have an account with Grainger which happens to be quite close to my home.
Thanks for your advice.
2001 Prevost XL II
Offline Sean
  • Geek.
    • Our Odyssey
« Reply #17 on: May 29, 2009, 10:42:39 PM »
Sure.  I would use this one:
http://www.grainger.com/Grainger/items/6C025
This is a White-Rodgers contactor with a 24-volt coil.  It is rated for 200 amps continuous, and 600 amps "inrush"  -- hard to tell from the Grainger page, but clear in the White-Rodgers catalog, here:
http://www.whiterodgers.com/wrdhom/pdfs/06_Cat_pages/Cat_06_pg0120.pdf
or the spec sheet:
http://www.whiterodgers.com/wrdhom/pdfs/sell_sheets/R-4005web.pdf
As I wrote earlier, you will seldom, if ever, see currents higher than 200 amps, and then only for a few seconds.  The rating on this contactor should be more than adequate -- it's rated for 50,000 cycles breaking 200 amps.
Offline paul102a3
« Reply #18 on: May 31, 2009, 03:37:27 AM »
Thank you Sean for the information on the contactor.
As a first time bus owner, it sure is nice that everyone is willing to share information. I thank all that have responded to my questions.
I am sure I will have many more as we start our adventures on the road.
2001 Prevost XL II
