June 24, 2018, 09:42:19 PM
Author Topic: Desktop Antenna/Receiver for WiFi-UPDATE-;-)  (Read 12826 times)
Offline Dreamscape
  • Dreamscape
  • Global Moderator
    • Dreamscape Eagle Travels
« on: June 04, 2009, 04:11:29 PM »
Yip, did a search here and nothing. ;)
Does anyone have any experience with using a wireless antenna for WiFi on their desktop pc?
I'm no longer gainfully employed, so need to send back my laptop and get our desktop set up. I could use my wifes new laptop, but she is using it for her medical transcription. So I need help, otherwise I'm netless! ::)
Thanks a bunch,
~Paul~
« Last Edit: June 11, 2009, 06:49:07 PM by Dreamscape »
Offline Eric
  • Currently in Northeast Ohio
Re: Wireless Desktop Antenna for WiFi
« Reply #1 on: June 04, 2009, 04:21:34 PM »
There are a Ton of options for you to think about! however My suggestion to you if your are a fulltimer is to consider a "directional" unit instead of an omni directional unit..Hawking makes a great product they are super simple Usb powered and you just point the little dish in the direction the wifi originates! This will get you a much better signal then a generic Omni...Now if you want a more expensive and complicated version we can set you up with an external setup...
Hawkings Little dish link http://www.hawkingtech.com/products/productlist.php?CatID=32&FamID=60&ProdID=379
Offline oldmansax
« Reply #2 on: June 04, 2009, 04:39:11 PM »
I am assuming you mean a wireless network interface card you would install in your desktop PC. If so, they work as well as the ones in a laptop and sometimes a little better. I used a wireless network in our last house and it worked fine. Make sure you buy a card with the same protocol that your wireless router uses. The old standby is the 811 "B". The newer & faster will be the "G". There are also some others by those two are most prevalent right now. Your documentation will tell you the protocols your router broadcasts. Make sure to secure your network once it is up & running.
HTH,
TOM
Offline Dreamscape
  • Dreamscape
  • Global Moderator
« Reply #3 on: June 04, 2009, 04:56:51 PM »
How hard is it to install a network card in a desktop? Really was hoping to find a plug and play, like using a usb port. I'm reading that the Hawking does use a usb port. I'm still on a learning curve with this, so bear with me while I learn.This one on Amazon is about 60 bucks, is this a fair price? Hawking HWU8DDA HiGain Wireless G Directional Dish USB NIC Antenna
I do understand that the direct signal would be strongest, at least that's what I'm reading. I'm not savy on all this gain and related tech talk.
~Paul~
Offline Eric
« Reply #4 on: June 04, 2009, 05:43:44 PM »
Sorry still figuring out the system here Yes that is a FANTASTIC price on that unit! It's the older model but is backwards compatible with most existing wifi systems out there. 99% of public wifi hotspots are backwards compatible both ways and currently Wireless "G" is the nominal there is a new version called wireless "N" out however the money for these Long range systems is still more $$$ then what most places want to spend! If you have windows xp or vista this unit is completely Plug and play.Also the advantage to a Usb unit Is you can swap it to a laptop or any other system you can use it on !
Offline kd5kfl
  • Jr. Member
« Reply #5 on: June 04, 2009, 05:44:13 PM »
Quote
I'm not savvy on all this gain and related tech talk.
I am. USB is a crockadoodoo. there isn't enough room for a powerful radio, a sensitive antenna or heat dissipation. there is not enough power available through a USB port for a decent radio. USB is for coffeeshops, libraries and offices.
An RV in a park can be a long ways from an Access Point. These are two way radios. don't be fooled by people who claim high power. both ends need high power for it to be effective.
the advice you have received is good. An external antenna that can be pointed at the nearest AP is your best alternative. Antennas affect both transmit and receive equally
Offline Hartley
Re: Desktop Antenna/Receiver for WiFi
« Reply #6 on: June 04, 2009, 06:50:15 PM »
Figure on spending $30 to $60 for what you need. I scan WalMart shelves and they usually have the Linksys / cisco stuff in that price range.
USB works fine up to 100 feet or more depending on where the AP is located.
A USB extender cable can move the little gidget up to a window and some duct tape
it should work.
Or an Internal card ( PCI type ) with a single antenna and extension cable for the antenna will work too.
Pawn shops sometimes have that stuff for $20 or less in many places.
Offline gumpy
  • Some Assembly Required
  • Slightly modified 1982 MC9
    • bus.gumpydog.com
« Reply #7 on: June 04, 2009, 08:38:02 PM »
I have used a PCI card in my desktop. It's an older PC, and I didn't have a laptop at the time. We took the PC to AK with us. It worked well if you could get close to the campground office, but typically, we were too far away. I had an external antennae that I could attach to it, also, but that didn't help much. It was an omni-directional antennae. Still, it was better than nothing, and usually, I could pull up by the office as we were entering or leaving and check email.
Another option might be to connect to your wife's laptop with an ethernet cable, and set up a shared ad hoc network interface to the wireless. That would work well if she's stationary, as in transcribing at a desk or table. Of course when she needs to move with the laptop, your cable has to be unplugged and you lose the connection. You could probably do this with 2 USB interfaces, too. One in each computer.
Offline Dreamscape
  • Dreamscape
  • Global Moderator
« Reply #8 on: June 05, 2009, 03:24:26 AM »
Craig, In laymans terms, we have an ethernet cable, do I just plug it in to the desktop and change/add a network?What is USB interfaces? Is that something to do internally to the puter? Sorry I'm just like a rock when it comes to this stuff. I'm showing my ignorance now! ;)
~Paul`
Offline happycamperbrat
« Reply #9 on: June 05, 2009, 08:31:18 AM »
Maybe I am not understanding the question. But I stumbled onto something helpful for us all. If you have a cell phone with internet access (Tmobile boost or ATT has sim cards you can buy for about $20.00 to get unlimited access) you can then buy an account at walkingwifi.com for $25.00 as a one time fee and your cell phone will connect up to 5 computers for free internet access. The only problem seems to be that it runs down your cell phone battery pretty quickly if it isnt plugged in. I havent tried it yet but it came highly recommended to me by someone I trust.
Offline Timkar
« Reply #10 on: June 05, 2009, 08:55:17 AM »
Hi Paul,
I am presently in my 5th wheel about 500 ft from the AP in the office. I had no connection unless I went close to the office.
I got one of these...Ebay  Item number: 120306817637  (no interest in company, just a satisfied customer) and now I get
2 bars out of 5 (about 30% signal strength) which is good enough for my "surfing, email, etc." Plugs in to the USB port of your PC
Take Care...Tim
Cawston, British Columbia
Offline JohnEd
« Reply #11 on: June 05, 2009, 10:27:54 AM »
KD5,
First off, I am not knowledgeable in this area, but I know a little tronics.  Your comment about the USB port made sense to me just on the surface of it.  There is a similar antenna being sold with RAVE reviews and I think it connects to the USB port.  They aren't claiming 37db of gain but it is healthy.  The spec the "max output power of 7watts".  Now, can that be true/possible connecting to a USB port?
The device isn't the parabolic one on the board.  This Ebay antenna/sig booster is item 120373654957 and it is some sort of flat panel.  I would appreciate your commenting on it performance.
Thank you,
Offline gumpy
    • bus.gumpydog.com
« Reply #12 on: June 05, 2009, 11:34:44 AM »
~Paul`
Paul,
By USB interface, I was referring to the inexpensive wifi adapters you can get a Walmart or Target which plug into a USB port and allow you to connect to a wireless router if you are within range. Basically, they are for laptops which don't have built-in wireless. I think they cost somewhere in the neighborhood of $20-$30 but not sure.
RE: Ethernet cable... yes, you basically connect the two computers (you'll probably need a crossover cable or will need to go through a router or hub). Then  you set up an ad-hoc network on both computers, and on the laptop, you set up internet sharing on the wireless connection that is used to connect to the internet. You might also need to bridge the ethernet connection that the ad-hoc is on to the wireless connection that the internet is on. I did this with a friend's laptop when I was in AL in Feb. He had an air card for his internet connection and I was in my bus. It worked pretty well other than his computer kept shutting things down.
craig
Offline Dreamscape
  • Dreamscape
  • Global Moderator
« Reply #13 on: June 05, 2009, 03:31:47 PM »
Thanks for the help guys! I have not made a decision, but getting close. Really considering the Hawking one that was posted earlier. We'll see if it fits the bosses budget!
Craig, I'll keep your suggestion in mind, sounds doable to me. I have the cable and switch, so I'm part way there.
I'm learning a lot, but still keep the ideas coming.
Offline gumpy
    • bus.gumpydog.com
« Reply #14 on: June 05, 2009, 04:00:36 PM »
Another medium cost option is to go to walmart and buy one of their Acer 9" laptops. They're like $300 for the basic model.  You can get it with either a 120 gig or 160 gig hard drive, or a 16 gig flash drive. Has built in wireless.  Comes with XP home edition, or, I think you can get Ubuntu (or whatever that Linux version is called). There's no cd drive in it, but if  you have another computer, you can share it and access it across your local network or connect a USB drive to it.
I got Teri one for Christmas, and it's turned out to be a pretty neat little computer. For the money, it's turned out to be a perfect computer for her.
craig
