June 24, 2018, 10:08:59 AM
Author Topic: rebuilt genset radiator enclosure  (Read 1974 times)
Offline Tenor
    • Three Men and a Tenor
« on: June 27, 2009, 07:01:12 PM »
Here's a shot of my old setup.
I found out that the old squirrel cage fan inside the enclosure was DOA.  The new one was about 2 inches wider so I swung the whole assembly over.  It also now uses the original circular access hole in the rear bulkhead to pull hot air out of the genset enclosure.  We had 85 degrees and the genset ran at 175 degrees while running 2 roof airs, inverter charging batteries, and the fridge.  I love it!
Glenn
Glenn Williams
Lansing, MI
www.threemenandatenor.com
8v71
4 speed Spicer
Offline JohnEd
Re: rebuilt genset radiator enclosure
« Reply #1 on: June 27, 2009, 07:10:22 PM »
The smell of success and the taste of victory.  And your cool too. 8) ::)
looks good,
« Reply #2 on: June 28, 2009, 08:50:13 AM »
Looks good!  If the duct tape does not hold, try Gorilla tape at Home Depot.  Good Luck, TomC
Offline Tenor
« Reply #3 on: June 28, 2009, 10:19:56 AM »
Thanks Tom!  I know I need to rebuild the panel that faces the side of the box since it has excess holes from running the radiator hoses for the previous location.  I figure, test first, build to spec later!  ;)
Glenn
Glenn Williams
Lansing, MI
8v71
4 speed Spicer
Offline Lonnie time to go
  • Lonnie
  • Saginaw, Michgan
« Reply #4 on: June 28, 2009, 10:39:22 AM »
Thank you for posting photo's .  It helps a newbee like me to setup my bus
I do hope to see you at the "back to the bricks" rally in flint  Aug 13-16
1976 4905
Offline Tenor
« Reply #5 on: June 28, 2009, 10:42:09 AM »
Hey Lonnie!
Yes, Amy, Matt and I will be at the back to the brick rally.  Will you have the bus there?  It's a great excuse to go for a drive!
Glenn
Glenn Williams
Lansing, MI
8v71
4 speed Spicer
  • Lonnie
  • Saginaw, Michgan
« Reply #6 on: June 28, 2009, 11:29:44 AM »
I am not sure if the bus will be there trying to get some tires.  If that goes well i should have the bus there.
1976 4905
