June 23, 2018, 06:03:21 PM
Author Topic: The Big Move-Scenicrusier- now completed  (Read 6549 times)
Offline kyle4501
  • NEWELL in South Carolina
Re: Getting ready for the Big Move-Scenicrusier
« Reply #15 on: July 20, 2009, 03:40:02 AM »
Good to hear the move went well.
I know how it is when it comes to taking pictures, way too many distractions . . . . .
Good luck with the rest. . .
Offline pd4501-771
  • Tom McNally
  • PD4501-771 "All 43 seats.....still a bus !"
    • Tom's Garage
« Reply #16 on: July 20, 2009, 06:23:05 PM »
Mike
We have talked via phone before. Refresh my memory.... Whats the serial number of you Scenic? Thanks
Tom McNally
Peoria, IL
PD4501-771
PD4501-1001
PD4104-3462
PD3751-686
If you know of the whereabouts of a PD4501 Scenicruiser - I would like to add the serial number to my registry of surviving Scenics.  www.tomsgarageonline.com
Offline Michael_e
  • Jr. Member
« Reply #17 on: July 20, 2009, 10:33:33 PM »
Hi Tom,
Serial - PD4501-278
And while we're here, approxmiately what kind of air pressure should i be seeing on the gauge when running? I don't have any of my books here and i think i remember seeing the gauge right aroung 95 lbs when airing up the bus for transport. I was using a sears portable compressor and it would shutoff itself at around 140lbs. Wondering if something goofy is going on with the gauge in the bus or what.
Mike
1955 GM Scenicrusier, 8V92TA & Allison 754. Totally rewiring all 12v systems and lots of questions.
Offline DaveG
Re: The Big Move-Scenicrusier- now completed
« Reply #18 on: July 21, 2009, 01:12:21 AM »
I'd think that your compressor has enough pressure and volume, but maybe you are not airing up the correct tank? Be sure you are airing up close to where the bus compressor discharges, ie wet tank, etc....just a thought.
Offline pd4501-771
  • Tom McNally
    • Tom's Garage
« Reply #19 on: July 21, 2009, 01:37:59 AM »
Hi Mike
Thanks for the serial number. I think mine stays pretty well at 120 when totally aired up. There should be a 3/4" pipe plug in a line, or near a "small football" shaped cast air tank towards the top of the bulkhead behind the engine. This is a good place to plumb a 90 elbow and run it out next to the radiator with a quick connect. Or there should be a fitting in the drivers tool compartment. (1st outside door on left side of coach, below drivers feet). Where are you connecting your air?
Tom McNally
PD4501-771
PD4501-1001
PD4104-3462
PD4501-771
PD4501-1001
PD4104-3462
PD3751-686
Offline Michael_e
  • Jr. Member
« Reply #20 on: July 21, 2009, 02:30:54 AM »
None of my air lines are original, or even in their original places. When i lowered the seat platforms, everything got relocated. I made a homemade sketch of how the lines were plummed, and then ran the lines in the same manner to where i relocated the tanks. I did add an air dryer to the system and placed it inline between the compressor and the first storage tank. I added a quick connect fitting right before that air dryer. What is sorta strange, is that the air gauge will show the pressure drop to about 20lbs in less than an hour, but all the air bags will hold a full charge for slightly over 24 hrs before they start leaking down. Confused?
Offline bevans6
  • 1980 MCI MC-5C
« Reply #21 on: July 21, 2009, 11:43:50 AM »
My guess is the gauge is reading the supply tank, the air bag suspension is fed from the accessory tank and there are check valves holding the air into the suspension.  On my bus the suspension holds for weeks on end, but the bus gauge reads 35 psi after 24 to 48 hours.  Why my bus stops leaking at 35 psi is a clue - to what I have no idea.
