This morning, during my third and final warm-up/cool-down cycle, I plugged in the DDR to check on everything. Specifically, I checked injector response, which looked good on all eight cylinders, ranging from 1.07 to 1.17. I also ran the injector cut-out test on all cylinders at idle as well as 1,000 rpm, and all injectors elicited a response, with pulse width increasing by 0.2 to 0.4 for each cylinder.For those unfamiliar, what this latter test does is to first report the amount of fuel being provided to the cylinders in the form of "pulse width" (PW), the amount of time the injectors are commanded to inject. Then it shuts off the injectors one at a time and reports the PW as each injector is off line. The idea here is that when a cylinder that was contributing real work gets turned off, the DDEC will have to increase the PW to supply more fuel to the rest of the cylinders to carry the load. If you turn off one injector, and there is no resulting change in PW, that means that that cylinder was not doing any work, which could mean a bad injector (or a number of other problems).I am interpreting the results, being fairly consistent across all cylinders, as meaning that I still have all eight injector tips, and all the exhaust valves are intact. I'm not conversant enough with these sorts of tests to rule out any other problems (low compression, marginal injector, etc.), but I am fairly confident at this point that the turbine failure was not due to FOD originating in the engine.
Jim, what good will a cut out test do except locate a bad injector it is not going tell anything other than the electronic part of the injector.
