Author Topic: Curious  (Read 2760 times)
Offline Bosshosssport96
Curious
« on: July 25, 2006, 09:13:31 PM »
A few days ago,I received my 8V92T,still bolted on was the clutch,pressure plate and throw out bearing,will these items work on a 8V71????Frank 4501-082
Re: Curious
« Reply #1 on: July 26, 2006, 09:58:43 AM »
I believe the bolt pattern is different.
Offline Happycampersrus
Re: Curious
« Reply #2 on: July 26, 2006, 12:38:46 PM »
The flywheel end of the 8V92 crank is larger than the 8V71.  :-\. The flywheels will NOT interchange. You can try and see if you can use the parts depending on which 8V71 flywheel you have. There are a couple different size clutches used and you might just have a match on the bolt pattern on the pressure plate.
Dale
Re: Curious
« Reply #3 on: July 26, 2006, 06:19:40 PM »
Thanks for the responses.........Frank
