June 25, 2018, 06:40:28 AM
Author Topic: Wheel seal?  (Read 8000 times)
Offline John316
Wheel seal?
« on: December 21, 2009, 10:24:19 AM »
We started throwing oil, from BETWEEN the drive duel's. There is absolutely no oil that we can see from the front (driver side), of the axle. Is that a seal leaking? If so, it just started.
BTW, the transmission is good...wheewww!!!
God bless,
Offline Ed Hackenbruch
Re: Wheel seal?
« Reply #1 on: December 21, 2009, 10:31:42 AM »
Sounds like it to me but i am no expert.  A shop where i was having some other work done on my bus found that one of my rear seals was starting to leak so i had them fix it. Could not see it until they took the wheels off for access for what they were doing.....on the other hand i now have a front wheel seal that just started leaking recently. Another project to do!
Offline gumpy
  • Some Assembly Required
  • Slightly modified 1982 MC9
    • bus.gumpydog.com
Re: Wheel seal?
« Reply #2 on: December 21, 2009, 12:02:17 PM »
By "between the drive duals" do you mean between the two tires on one side, or in the middle of the coach between left and right duals?
Typically, oil from a seal will leak inside, behind the duals. Are your wheels open, or do you have covers on them (simulators, hub caps)?
Could also be an axle gasket on the hub.
It's probably a wheel seal. You'll have to pull the axle and hub to replace it. Possibly your brakes are oiled now, too.
Offline bobofthenorth
    • R.J.(Bob) Evans
Re: Wheel seal?
« Reply #3 on: December 21, 2009, 12:15:51 PM »
Generally seals don't go out spontaneously.  Sometimes a new one will fail to seat properly but if a seal starts leaking after it hasn't been leaking for a long time I'd be looking hard at the bearing.  Something caused the seal to start leaking.
R.J.(Bob) Evans
My website
Our weblog
Offline johns4104s
Re: Wheel seal?
« Reply #4 on: December 21, 2009, 12:57:13 PM »
If your coach has stood for long periods then the seals tend to leak when you start to put the miles back on it. A fellow once told me the one area of maintaence he would do on a used coach purchase would be to change out all the hub seals. He is right as 5 of my seals have started to leak since I purchased the coach 2 years ago.
Offline DaveG
Re: Wheel seal?
« Reply #5 on: December 21, 2009, 05:07:35 PM »
Craig...good questions to ask and get answered.
By the way & FWIW, some older hubs used a "slinger" set-up that would sling the oil from the leaking hub seal out onto the wheel area rather than contaminate the brake lining.
Offline John316
Re: Wheel seal?
« Reply #6 on: December 21, 2009, 06:40:08 PM »
Thanks for the replies, guys.
Here is the scoop. It was/is a leaking seal. I was able to get it into the shop today. They also found that the seal on the other side, was leaking too.
We do have simulators on there, but they are coming off. I would have changed the seals myself, but I don't have a torque wrench, that size, and I don't have the time.
It was slinging the oil from between the duels (between the two drive tires). It was getting slung out, and I could smell it, hence why I checked. Those seals were brand new 30K, ago. So I don't have any clue why they would be leaking. They shouldn't be, since everything was rebuilt/ replaced. They are also checking the bearings, while they are in there.
Dave, we don't have that "old slinger" style. That is how I knew they were leaking and have never leaked before.
Bob, I sure hope that it is something spontaneous, but we will find out. Central Power is working on it tonight (I know, they aren't your usual shop, for that kind of stuff, but we trust them, it is so hard to find someone you trust).
God bless,
Offline gumpy
    • bus.gumpydog.com
Re: Wheel seal?
« Reply #7 on: December 21, 2009, 07:08:07 PM »
A very well respected bus mechanic told me recently (when I had 2 seals go on mine) that leaking seals are usually the result of over-tight bearings.
Just passing that on. Can't confirm it, but trust everything he says about buses. I the one who replaced these, and while I don't believe they were too tight, I have never
claimed to be an expert on anything. Will see if any more go out as I set the bearings the same on all of them.
Offline John316
Re: Wheel seal?
« Reply #8 on: December 21, 2009, 07:33:40 PM »
Fascinating, Gump. Thanks for the info. I will keep that filed ( ;)) in the back of my mind...somewhere.
Great info. Thanks!
God bless,
Offline buswarrior
  • '75 MC8 8V71 HT740
Re: Wheel seal?
« Reply #9 on: December 22, 2009, 07:42:17 AM »
Wheel seals are consumables, and best changed out on a schedule, not on failure.
In commercial service, pulling the wheel end apart for a regulated annual inspection is a fine trigger to put in fresh seals.
In busnut service, we are perhaps less vigilant in taking the wheel ends apart for inspection...
A leaking wheel seal lands you smack into the middle of the debate on whether or not you have ruined your brake linings by way of oil soaking them. (NO, don't start it again here, please)
Another bit of inspiration to doing some periodic tear down for inspection?
All the parts will come apart, if taken apart on some regular basis.
Greasing the various bits and pieces is so much easier with the thing disassembled.
Inspect and re-lube the bearings
Inspect, clean up and lube the brake components.
Install fresh wheel seals and fresh hub seals.
Record the measurements taken of your brake lining thicknesses for comparison to next time.
Confirm the inside measurement of the drum is within spec, if not checked during your ownership.
And down the road you go with a greatly reduced chance of failure, and you know the condition, rather than blindly hoping...
Offline edroelle
  • 1998 Royale Prevost
Re: Wheel seal?
« Reply #10 on: December 22, 2009, 08:59:45 AM »
Luke recommends grease as opposed to oil on conversions because of limited use.  I have changed some to grease, especially if there is wear on the spindle that a sleeve may not correct.
Bus Warrior - your opinion please.
Ed Roelle
Flint, MI
Offline johns4104s
Re: Wheel seal?
« Reply #11 on: December 22, 2009, 10:04:19 AM »
Buswarrior,
Very good input,
Offline bevans6
  • 1980 MCI MC-5C
Re: Wheel seal?
« Reply #12 on: December 22, 2009, 10:56:51 AM »
when talking about wheel seals and grease and all of that, it's useful to also say if you are talking about drive axles, tags or steer axles.  Each is different in what it wants and what is needed to work on them.  I would think that drive axle seals would or could be replaced any time you have the drum off to do brakes, wouldn't they?  Tags and steers I think you can take the drum off without disturbing the wheel seals.
brian
Offline gumpy
    • bus.gumpydog.com
Re: Wheel seal?
« Reply #13 on: December 22, 2009, 11:03:31 AM »
brian
They're pretty much the same. You have to disassemble the hub to replace seals.
The drums will come off the hubs without removing the hubs from the axle. That's true on all three axles.
To replace the seals, the hubs have to come off the axle. For steer and tag, it's just taking it off the spindle. For drive, you have to remove the axle from the differential tube, first.
None are overly difficult. Just messy and time consuming.
Re: Wheel seal?
« Reply #14 on: December 22, 2009, 12:18:09 PM »
Every job for me is messy. :)  All i have to do is open the engine compartment door and i am dirty. In fact i can watch somebody else open their door and i get dirty. :(    I learned a long time ago to just put on clothes that i am going to throw away when i get through wearing them,  if i am going to do anything to my bus or cars.  I swear that dirt and grease can actually jump several feet when they see me nearby. ;D
