Brian,
I would also suggest that if you have your misters controlled the the compressor circuit, you unclude some kind of time delay so that the water continuse to run for a minute or two after the compressor shuts down. This will cool down the condensor so the water doesn't boil off as fast, perhaps leaving fewer deposits.
If you are using a water tank, then distilled water might help.
Len
