June 23, 2018, 08:15:15 AM
Author Topic: V730 pressure checks  (Read 1169 times)
Offline olebusman
  • Jr. Member
« on: January 12, 2010, 01:14:00 AM »
 Hello all!!  Need some help. Does anyone have,or know where to find, a pressure test procedure for the V730D tranny? I just installed mine with a 6V92TA engine and a Teal o-drive setup. It come out of a 82 Flex transit. Engine had a loose gear on a cam. It jumped time and broke the valves and pushed through the head. Well a rebuild later and the input shaft for the o-drive, welded at a shop-I could have done better with jb weld, broke so pull the tranny out.  OK fixed again. Now after about 200 miles it goes about 40 miles then when it shifts down to second it won't go back into drive and stay there. I can shift back and forth 2nd to 3rd and sometimes it will go back in to drive. Using 30 weight delo 400 oil and all cooler and filter lines are the same size as on the flex. It don't feel as if it is slipping but it feels like the converter stall speed is high, don't know what that should be either. Open to all suggestions. It is full of oil and the temp runs about 160 in the pan and 210 converter out. By the way the Teal o-drive is so nice. Thanks  olebusman
Offline Barn Owl
  • Roanoke, VA
  • PD4106-1063 "Wheezy Bus"
Re: V730 pressure checks
« Reply #1 on: January 14, 2010, 04:35:27 AM »
I can get them by Sat. if no one else has before then. I have a V730 manual. Where does one find info on the Teal o-drive? I am interested.
Offline olebusman
  • Jr. Member
« Reply #2 on: January 15, 2010, 02:05:49 AM »
 Do a search Bill Teal is the gentlemans name. It uses parts from a VS-6 and a VS-8 planetary setup between the engine and the tranny. In a 4106 the Allison needs a spacer between engine and tranny so there is room for it. I have the directions to do the mod. but it would not be fair to Bill for me to post them.  olebusman
