4drifter,
Was the engine properly sealed while it was sitting? Like the exhaust ports! If they were left open to the air for an extended time,
You can devolep corrosion on the cylender walls, and upon starting up the engine, cause excessive wear on the rings and cylendar
walls. I sure hope this is Not the case and maybe it's some other simple problem!
Good Luck
