June 23, 2018, 02:17:24 PM
Author Topic: Needed 250amp DC Disconnect  (Read 3219 times)
Offline faster_freddie
« on: August 03, 2006, 06:43:08 PM »
I need a 250amp DC Disconnect to use with our Trace SW4024 inverter.  If you know where I can get one at a good price ($100.00 or so) please let me know.  I'm im Pahrump, NV  89048.
Fred
fn1@mac.com
Offline Devin & Amy
  • FMCA#377731
  • 1980 MC9 8v71 4spd man. Fulltiming family of 6
Re: Needed 250amp DC Disconnect
« Reply #1 on: August 03, 2006, 06:49:08 PM »
Fred,
I finally went to a high-end stereo shop after not finding one any where else. The brand is Stinger. They come in 150, 200, 250 Amp versions. I bought the 200 Amp version for 69.99+tax. one benefit is they look pretty also, gold-plate.
HTH
Devin
Devin, Amy, and the kids!!
Happily Bussin'!!
Offline Kristinsgrandpa
  • 1988 Neoplan AN 340, 6V-92 TA DDEC II, HT 748 ATEC
« Reply #2 on: August 03, 2006, 07:29:33 PM »
Northern Tool and Harbor Freight both have battery disconnects, but they are low amps.
www.jcwhitney.com shows 3, one is listed at 1000 Amps for $30, no. zx 749003w,
one for $19 listed as 500 amps, no zx 150856 y,  Both lockable, and one non locking for $28 no. zx 747827 p with no amperage listed.
HTH Ed.
Offline Paso One
« Reply #3 on: August 03, 2006, 07:53:21 PM »
 I notice the Xantrex Pro Watt 3000 recommends a 400 amp DC fuse. They sell that for 97.50 can or 85.00 US I wonder why the differance??
68 5303 Fishbowl 40' x 102" 6V92 V730  PS, Air shift  4:10
1996 MCI 102 D3
  • Global Moderator
  • Nick & Michelle Badame
« Reply #4 on: August 03, 2006, 11:10:18 PM »
Fred,
This is the disconnect most of us use.  It's 400 amp. Available from Wytek Wire.  About 112.00
http://order.waytekwire.com/CGI-BIN/LANSAWEB?WEBEVENT+L0B61FB6273340900054D041+M37+ENG
Hummm, It's not loading....   Try www.waytekwire.com
than search, battery disconnect  or item #  44033
« Last Edit: August 03, 2006, 11:24:01 PM by Nick Badame Refrig. Co. »
Offline jjrbus
  • MCI5C/N Ft Myers FL
« Reply #5 on: August 04, 2006, 01:01:46 AM »
This is a good area not to skimp. I'm cheap but with this high amperage stuff you really have to do it right!  Now being cheap the first option if you have a old bus available is the battery disonnect out of one. That is what I used for one switch, I did not see a rating on them but they are very heavy duty, really built to last. Also on an MCI if you get rid of the road air the selonoid from the AC is rated at 250 amps.
 The second option for a lot of this hevy electrical equipment is marine supply places, West Marine, Boat US, Boaters World. They all have catalogs and websites if you do not have one near. They carry Perko switches that are rated at 240 amps  that is 250 amp continuous and 360 amps intermittent. they start at $20 and for $70 you can get a 380 amp continusous  850 amps intermittent this is a 4 position switch and is what I use for my selector switch. They are also a good source for fuse's fuse holders, good tinned cable ends. Pricey but they have the things you need and are high quality.
        Work?/Play safely Jim
Offline ChuckMC8
  • 1977 MC8 and 1993 102C3 Temple Ga #322 F&AM
« Reply #6 on: August 04, 2006, 06:11:14 PM »
I needed a disconnect between my house batteries and my inverter....I used a spare factory MCI main electrical switch( the one everyone uses to switch the coach batteries on & off) these should be inexpensive used from Sam Caylor or someone may have an extra lying around......
Hey that was my 100th post! (Since the new board) Wonder how many I had the past four years? :)
« Last Edit: August 04, 2006, 06:13:10 PM by ChuckMC8 »
