Author Topic: 0 - 60 times - lets hear them...  (Read 7835 times)
Offline viento1
    • my website
« on: February 25, 2010, 10:39:21 PM »
There are a few threads on ratios and speeds. I decided to take a few passes with the old girl
I am not sure if my speedo is accurate but my average over 3 passes is 42.1 seconds
1968 MC5
3.71 rear end
8V71 with 65 injectors
Not sure if timing is advanced.
Full fuel tanks but not sure on overall weight
Top speed is about 75mph
Lets here what you've got Ed :)
Ok, it's time to go on another road trip.
www.randalclark.com
MC5
Offline zimtok
    • Eddie Smith, the reason for having the bus
Re: 0 - 60 times - lets hear them...
« Reply #1 on: February 26, 2010, 06:17:48 AM »
I guess in the spirit of the Olympic games I can get some "speed times" on the old bus.... I may need to use a calander instead of a stop watch though..... ;)
GMC 4104....ZOOM...ZOOM
1960 PD4104-4971 - Memphis TN
Buy the new Eddie L Smith CD "STAYIN LONG" at:
http://www.eddielsmith.com
Everyone is welcome to any of our gigs listed on the website.
cody
« Reply #2 on: February 26, 2010, 06:44:02 AM »
My best time tru the traps was august.
Offline Ed Hackenbruch
« Reply #3 on: February 26, 2010, 06:50:18 AM »
Randy, i have never thought to check my 0-60 time!  :)  I am usually pretty light on the throttle when taking off, and let off on the throttle way before coming to a stop, in the interest of better fuel mileage. ;D We won't be leaving Yuma until the 1st of April this year unless the boss calls me for work before that. Usually we stay till the 1st of May or so, but since it looks like i will be working on the other side of the mountains again this summer we will be starting work earlier. I will try to remember to take a few readings on our trip up. ;D  Ed
Used to own a 1968 MCI 5A with 8V71 and Allison MT644 transmission.
« Reply #4 on: February 26, 2010, 06:54:46 AM »
Cody, isn't that the week that the snow is off of the roads up there? ;D
Offline Lin
  • 1965 MC-5a
« Reply #5 on: February 26, 2010, 07:33:36 AM »
I haven't timed it yet, but found it is amazingly fast heading down an 8% grade.  I think acceleration approached 32ft/sec/sec.
« Reply #6 on: February 26, 2010, 07:35:54 AM »
 ;D
Offline RTS/Daytona
  • Pete RTS/Daytona ->'89 TMC 35' 102" 6V92TA 4:10
    • BUS CONVERSION PARTS FOR SALE / PROJECTS
« Reply #7 on: February 26, 2010, 07:43:44 AM »
POOR MANS DYNO  -  77 MPH top speed --
I have always recorded the times 0-60 on a flat road for every RV vechicle I've owned - helps to let you know if your engine getting weak a few years down the line
works for me
the 0-60 in 27 seconds (.pdf file) was our Classic 1976 GMC 455 cu-in Olds Toronado front wheel drive 26'
« Last Edit: February 26, 2010, 07:56:37 AM by RTS/Daytona »
Offline PCC
  • Serving Those Who Have Served
    • Serving Project, Inc.
« Reply #8 on: February 26, 2010, 07:57:13 AM »
From the top of the hill (7% grade), to the bottom, from a standing start, with a good tail wind, I was able to do it in under a minute.
I love soap box racers.
Offline WEC4104
« Reply #9 on: February 26, 2010, 08:22:05 AM »
From a dead stop, my Onan will do 0 - 60 (Hz) in a little over two seconds.
Offline bevans6
  • 1980 MCI MC-5C
« Reply #10 on: February 26, 2010, 08:28:24 AM »
Pete, was the 277 an input or an output from the program?  I was doing some reading, and for my nominal 280 hp 8V-71 I would expect to take away 15% for driveline losses and about 30 - 40 hp for the squirrel fans and the alternator and other drive items.  so I would have about 200 drive tire hp.  I was reading this:  http://www.holtrv.com/pdf/understanding.pdf  and reading about hp requirements for grades and speeds and such.  It seems to use rear wheel hp.
Offline RTS/Daytona
« Reply #11 on: February 26, 2010, 08:36:25 AM »
I believe that's 277 hp (at the flywheel) - I have a California EPA 6V92TA engine with a catalytic converter - / low smoke / low emiisions /
still penty peppy for me - does real great on the hills (I pass trucks) - and If i cruise at 62-65 - I can get 9-10 MPG
Offline buddydawg
« Reply #12 on: February 26, 2010, 08:51:37 AM »
0-60??? My top speed is about 63 MPH !! I'll go for a spin this weekend and get a measure.
1972 GMC T6H-5308A #024
Brandon Stewart - Martinez, GA
Offline Iceni John
« Reply #13 on: February 26, 2010, 12:59:05 PM »
I have the 277 HP Californicated 6V92TAC DDEC II in my bus, with the same 4.1 rear end and probably about the same weight (your 35' is converted, my 40' is a tin tent and weighs about 25,500), and I'm guessing your bus may be a smidgeon more aerodynamic than mine.   At a steady 60 MPH (just under 1900 indicated RPM), using 12R22.5 Michelins, I'm not getting 9 to 10 MPG.   What's your secret?   If I had my injectors replaced, would that help my fuel mileage by any noticable amount?   Just curious (and slightly envious).
2kW of tiltable solar.
Offline bevans6
  • 1980 MCI MC-5C
« Reply #14 on: February 26, 2010, 01:04:40 PM »
his charts said he was 19K lbs, that would make a difference from 25.5K.  Also he said a 3.60 final drive ratio, also a big difference from a 4.10
