Author Topic: White smoke  (Read 1690 times)
Offline wal1809
White smoke
« on: May 04, 2010, 08:23:56 PM »
My buddy got the mci9 he is thinking about buying started.  He says even after an hour he still has white smoke, and lot of it.  Any ideas.  My first thought is to get the old fuel out and replace with new.  Just for shizzles and grins.  Any thoughts ?
www.snakebreaker.com
Online luvrbus
Re: White smoke
« Reply #1 on: May 04, 2010, 09:14:18 PM »
Wayne, he has cylinders not firing I doubt if it is old fuel
Offline wal1809
Re: White smoke
« Reply #2 on: May 04, 2010, 09:19:01 PM »
Hello luvrbus would that ne bad injectors?
Online luvrbus
Re: White smoke
« Reply #3 on: May 04, 2010, 09:30:54 PM »
Wayne, it will be a compression issue, bad injectors with good compression it would be black smoke
Offline wal1809
Re: White smoke
« Reply #4 on: May 05, 2010, 03:24:05 AM »
Thank you Sir I will pass it along.
Re: White smoke
« Reply #5 on: May 06, 2010, 09:13:04 AM »
White smoke=unburned fuel with low compression-or it could be steam from a cracked head leaking coolant into the combustion chamber.  Good Luck, TomC
