Author Topic: DD alternator horror story  (Read 7777 times)
Offline JackConrad
  • Orange Blossom Special II
  • Global Moderator
Re: DD alternator horror story
« Reply #15 on: May 18, 2010, 09:07:53 AM »
Yes, as Van said. I made one several years ago for a friends 4104 (L6-71) so he could drive it home to CT. I used a piece of 1/4" flat stock.  Jack
Offline JohnEd
« Reply #16 on: May 18, 2010, 10:20:17 AM »
AND to further amplify the pucker factor:  Rick told me that the "older version of the 50 DN were worse than the newer models".  I didn't dig into that comment because he looks at the 50 as an end item and doesn't associate it with an engine or bus model.  The Knuts here could probably expand on that topic with much more useful info.  To me that meant that the 4104 and 4106 guys had more to be concerned about, but, as was stated, that may not be much.
I did pick up an interesting tid bit though,  Rick scoffed at the idea of having the 50 oriented properly for the oil cooled version.  He said that that didn't matter and that it would cool ok regardless.  I have read posts where the owner was cautioned to remove his 50 and put it back with the ??? pointed "up"....flat spot?  Considering that you need a crae to lift the thing in and out, not having to do that is some sort of really good news.
Offline Tony LEE
    • Photo Albums
« Reply #17 on: May 18, 2010, 11:36:36 AM »
If the orientation is wrong, the diodes may not be immersed in oil, so the unit would need to be downrated significantly
Offline JohnEd
« Reply #18 on: May 18, 2010, 06:09:26 PM »
Tony,
Your comment was mine and it still makes sense to me.  The re-builder said it didn't matter and his advice is counter intuitive.  I think he said there is an awful lot of oil going thru it and any diode in there will be wet often enuf.  But I don't know.  I do know that if I installed one it would have the flat spot up?
John, it ain't my lie
