June 25, 2018, 03:06:24 AM
Author Topic: Freon replacement for R-22 ?  (Read 7554 times)
Offline robertglines1
  • steam nut
« on: May 22, 2010, 05:38:50 AM »
Is there a direct replacement for R-22 freon that is available to the public..for the do it yourselfer...
Offline James77MCI8
Re: Freon replacement for R-22 ?
« Reply #1 on: May 22, 2010, 12:06:00 PM »
Check out this link
http://www2.dupont.com/ISCEON/en_US/products/ISCEON_MO99.html
You most likely won't be able to buy this unless you have certification in recovery and charging HVAC equipment.
77 MCI 8
8V-71 4 spd
  • steam nut
« Reply #2 on: May 22, 2010, 12:18:33 PM »
Thanks I have a friend in hvac business (local) and is a bus nut...will contact him and see if he can help me out...
Offline Ray D
« Reply #3 on: May 22, 2010, 05:55:05 PM »
Get on  macsw.org  pay your'e $15.00,  take an open book test, get you're freon certificate and go buy some R-22.  It is that easy, I just did it last year and the certificate has not been refused by anyone.
Ray D
  • steam nut
« Reply #4 on: May 22, 2010, 07:13:55 PM »
Good idea about certificate...I have gauges and worked supper market and home re fridgeration in my youth.was no rules then..
Offline Hi yo silver
« Reply #5 on: May 22, 2010, 07:32:06 PM »
Freeze 12 is working well for me in the original over-the-road a/c.
Dennis
  • Global Moderator
  • Nick & Michelle Badame
« Reply #6 on: May 23, 2010, 03:58:58 AM »
Hi Robert,
The R-438A gas just happens to be Duponts brand and will work just fine.
I use 407-C and 417-A which are also direct drop in refrigerants for R-22.
According to my suppliers, there is enough R-22 around to last about 10+ years...
Another fact,  the price of a 30lb tank of R-22 is still lower then the replacement gasses...??..??
Things that make you go Hummmm!
Have a great day!
Offline Hard Headed Ken
  • 1988 Prevost Angola Conversion Repowered With 14L Series 60 & Eaton Ultrashift
    • Link to my engine swap
« Reply #7 on: May 23, 2010, 05:16:38 AM »
Is it true that the replacements are 10% or so less efficient than R22?
Ken
  • Global Moderator
« Reply #8 on: May 23, 2010, 07:54:27 AM »
Hi Ken,
More like 5% but only when used in systems that they are not designed for Like R-22..
Hope this helps
Offline James77MCI8
« Reply #9 on: May 23, 2010, 12:06:38 PM »
What are you charging up Robert?
77 MCI 8
8V-71 4 spd
  • steam nut
« Reply #10 on: May 23, 2010, 12:10:18 PM »
was thinking about building my own mini split out of some old window ac I have...15000 120 v0lt
