Author Topic: need help to find exhaust pipe  (Read 3243 times)
Offline David Anderson
  • just outside San Antonio TX
« on: August 14, 2010, 11:37:44 AM »
The more I dig around in replacing the tranny hoses the more I find.  This is a good time to fix everything on the radiator side.  My exhaust manifold is shot.  Luke has the part.  Now I need the exhaust pipe from the manifold to the turbine and the clamp.   Where can I find this?  Pictures below:
Re: need help to find exhaust pipe
« Reply #1 on: August 14, 2010, 12:48:57 PM »
David, Jefferson has that pipe you are not going to like the price that pipe with the expansion bellows runs from 200 bucks up DD is asking 480.00, Jefferson is a little over 200.00 he has those made somewhere.
Too bad you don't have the top mount turbo I have a new SS bellows pipe for the top mount turbo.
Offline John316
« Reply #2 on: August 14, 2010, 12:49:58 PM »
Clifford, can he get a new one made himself?
Probably not for under 200 though...
God bless,
« Reply #3 on: August 14, 2010, 03:35:31 PM »
Thanks Clifford,
I figured it would be about $200.  The exhaust manifold will be about $300 from Luke when he finds it.  Plus I need to replace at least one clamp.  I didn't even think about Jefferson having that.  I'll call them Monday.  I wonder how they know the correct bend I need.  Is this a standard configuration on a lot of Model 10's?
David
« Reply #4 on: August 14, 2010, 03:55:44 PM »
David,it was standard set up on your model of 10 then they changed to the top mounted turbo for the later model 10,15 and 20.
Not to say any thing about the price Luke is charging for the manifold but Pedco will sell you that manifold for around 150 bucks one for a 8v92 cost me 175 bucks call Mondo at 562-944-3199 with the casting number also Don Fairchild may have one  661-301-4648 three hundred is a little pricey for that little manifold    www.dieselpro.com sells aftermarkets also
« Reply #5 on: August 14, 2010, 05:06:14 PM »
Unfortunately, I cannot read the casting on the manifold.  I took 8 pictures of it and emailed it to Luke.  So far, he is not 100% sure of which one it is.   I may have to send it to him.
David
« Reply #6 on: August 14, 2010, 05:30:05 PM »
David, have you called Jim he still has the 6v92 that came from his Metro Eagle at least he did the last I heard
Offline rv_safetyman
  • Jim Shepherd
    • Bus Project Details
« Reply #7 on: August 14, 2010, 06:38:22 PM »
David, I do have the manifolds.  Not sure about the tubing.
Jim Shepherd
Evergreen, CO
« Reply #8 on: August 16, 2010, 03:41:30 PM »
Jim,
I ordered the manifold from Luke today, $300.  Jefferson doesn't have the exhaust pipe, but it is $457 plus shipping.  Are there any other alternatives on finding the pipe?  That seems really high.
David
« Reply #9 on: August 18, 2010, 02:21:58 PM »
Finally found the pipe.
Armando at Pedco (he answered the phone as Iron Man Parts) 562-944-3199
found a take out in the yard with a clamp.  $195  Thanks for the lead on this Clifford.
Pipe on its way and manifold on its way from Luke.   Maybe by next week I'll have this project complete.
David
