Author Topic: Crazy and not crazy "get'er home" fixes and other errors in judgement/hindsight  (Read 10670 times)
Offline JWallin
  • Jr. Member
Well, we didn't have to fix anything in the field...but some years age a friend and I were in the Abaco's (Bahamas) and were preparing to leave when we discovered that the bendix on one of the starters on our Piper Aztec was frozen. We tried beating on it, spraying it with Blaster, talking to it...nothing worked. Since there are no repair services there at all, and the only alternative was to fly in parts and a mechanic from Florida... we decided to prop it. An interesting experience on a cub, a whole different animal when it's a 250 hp I/O 540. Well we finally got her running though it took a while since it was cold, and made it back to Florida. Then Customs made us shut her down for their inspection. Then we got to prop her again to go on home.
HighTechRedneck
I could go on and on for get-er home fixes but they wouldn't pass DOT regulations. So I'll keep my mouth shut so I don't get people all upset!
:(  BK  :(
BK's most famous one ;D :
artvonne
  I think I would rather take my chances crawling under an air suspended bus without blocks, before I would want to hand prop a big aircraft engine. I recall some old pilot saying something about only propping engines that dont have starter motors. They have starters for a reason, lol.
  There was a wrecked Cessna 172 out at the airport. Story was it was cold out and wouldnt start. So the guy jumps it off his car and put his 11 year old son at the controls to hold the brakes. The poor kid couldnt hold it back when it lit and it took off acrosss the ground and stuffed itself between two hangers. Good thing the hangers stopped it. Dont jump start airplanes without licensed pilots at the controls.
  We had a guy out at the airport who put his hand on the prop of a Bonanza parked in the hanger, and it started. Someone had left the mags on. The guy put out his hands and grabbed the spinning prop cone, and somehow pushed himself away from it. Dont touch props unless you intend to start one, or die.
Offline happycamperbrat
On my Crown Vic, Ford had a lawsuit that I missed out on. The Intake Manifolds were made of plastic! By the time mine split and I found out about the lawsuit, the time was up for replacing them for free. To get me by while I saved the big buck$ all I did was use JBweld to hold it together. About every 50 miles or so I had to reapply it.
Offline Busted Knuckle
:(  BK  :(
Yes and I'm sure it wasn't approved by DOT having the team push it out of the middle of the road, or the "fix" to get 'er home! ;)
