Author Topic: Pics  (Read 11536 times)
Offline DrivingMissLazy
Re: Pics
« Reply #30 on: September 03, 2006, 05:30:31 AM »
Brill-0, based on Nick's reply, you can unlock your project and let everyone enjoy the fruits of your labor.  :)
Hello Rihard, Phil,
Non members Can view posts. However, they can Not view member profiles or make posts themselves.
Hope this helps
Re: Pics
« Reply #31 on: September 03, 2006, 09:35:28 AM »
Brill-0- Just went through all the picts, I can say that the bus looks remarkably good considering the years of neglect.  Course they don't build anything that heavy duty anymore.  Was impressed with the behind dash picts of all the braided lines with brass fittings and some brass lines.  Most all is plastic now.  It's great that you've been able to look beyond the bad paint and dirt for this project.  Am quite amazed you got the engine running.  I thought the radiator was in front, but looks like it is angled right in front of the engine-am I right?  The underneath is going to need a serious steam cleaning.  I assume you are going to be taking everything apart and rebuilding it to safe standards?  I know some things are unique, but one I would suggest is to deactivate the parking brake and install Maxi brakes.  Those driveline parking brakes aren't worth much except to hold the bus in place-let alone trying to stop in an emergency.
This reminds me of when I got my bus and took it apart how dirty it was-and it had been in active service.  Yours is a whole other story.  As a suggestion- you could do a full conversion, but do what I did and screw with metal bracket everything, then you can just take it apart again if you want to change it back into an antique bus in original condition.
Hope all goes well and keep us up with the picts and updates periodically.  Good Luck, TomC
