BTW, I am at about 46K with the 9.6K service truck.I don't have any information to say that the ISB will not do a reasonable job in a lighter bus. As has been pointed out, it is/has been used in some motorhomes. However, when we start talking about 40 foot buses, they are often over 35K and some well over that. Then you add a toad. The Series 60 and other class 8 truck engines are very heavy duty and are designed to run all day under heavy load for 500K or more miles. The have very strong blocks, cranks, and cylinder liners. I don't think the ISB is that kind of engine. Yes, you can modify them to get some pretty good HP and Torque, but in an RPM range that probably requires some unique gearing that is not readily available for buses.Jim
Cummins ISB 6.7 liter for motorhomes is currently rated at 360hp @ 800lb/ft torque. Considering the 8V-71N with N65 injectors is rated at 304hp @ 800lb/ft torque, the hastle of changing the engine over is just not worth it. Granted, you might get 1-2mpg better, but that improvement in fuel mileage would take a long time to see any advantage. Better you either turbocharge the 8V-71N (I know personally that that works extremely well) or go with the larger ISC or ISL (same block) for a maximum of 450hp @ 1200lb/ft torque. THEN you'll have some performance. Good Luck, TomC
Quote from: kyle4501 on October 28, 2010, 12:39:06 PMNeither is ignoring or failing to understand or investigate the reasoning behind current standards Again, current standards are all designed for commercial duty cycle. Name one OEM that design for busnuts?RV manufactures seem to agree with me, if they tune an emissions choked ISB to 360hp (easy 400hp without emmissions).
Can you post the names of the 6 engineers and their PE registry numbers please?
