Author Topic: Venting Furnace Through Bay Door  (Read 5627 times)
Offline Tenor
    • Three Men and a Tenor
Re: Venting Furnace Through Bay Door
« Reply #15 on: November 18, 2010, 09:13:19 AM »
I installed 2 furnaces (suburban's) in the coach.  One in the front under the couch and the other in the rear under a bunk and venting into the bathroom and rear bedroom.  I love it!  Easy zoned heat.  I also wanted to stay away from the atwood because of the large hole needed in the coach wall.  Using the structural diagram in the parts manual, I was able to only put holes in the skin, not through any structural element.  I wouldn't want to put one in a bay unless it too was kept warm.  Too much heat loss in ducting  back into the bus.  Just my opinions, and I will never say you shouldn't do what works for you!
Glenn
Glenn Williams
Lansing, MI
www.threemenandatenor.com
8v71
4 speed Spicer
« Reply #16 on: November 18, 2010, 09:57:56 PM »
Both Atwood and Suburban make remote breathers that do not require the big mounting hole in the side of the bus anymore.  Good Luck, TomC
