Author Topic: Is my transmission toast?  (Read 21934 times)
Offline robertglines1
  • steam nut
Re: Is my transmission toast?
« Reply #15 on: January 03, 2011, 12:29:03 PM »
how far was it down? transmission wireplug wet-speed sensors in rear differential-air line tore loose? Good luck.
Offline H3Jim
« Reply #16 on: January 03, 2011, 01:07:45 PM »
the far rear was down far, trailer hitch about 4" in the dirt.  I don't think the differential was even close to hitting.
Attached, I hope, is a picture
Jim Stewart
Offline H3Jim
« Reply #17 on: January 03, 2011, 01:45:18 PM »
Talked to the free emergency tech at Prevost.
He confirmed that its not likely that the reset would work as the computer seems to be working - iot does shift into 1st gear.
I checked for codes and there are no codes.
He said the next thing to try is to carefully clean the battery posts for the 12 volt circuit - even though the bus starts (on 24 volts) if the 12 volt batteries have corrosion or are not fully charged, it can make the tranny computer go crazy.
He said that if that does not work, it needs to get itself to a shop.
Jim Stewart
Offline Busted Knuckle
« Reply #18 on: January 03, 2011, 02:05:59 PM »
Great news! Did he mention a FREE way for it to get itself to a shop? ;)
Offline rv_safetyman
  • Jim Shepherd
    • Bus Project Details
« Reply #19 on: January 03, 2011, 02:24:15 PM »
Jim, I have to wonder out loud if the parking brake and transmission are related.  The DDEC has a signal from the parking brake.  It, for example, will not go to high idle unless the parking brake is on.  The engine talks to the transmission and I wonder if there is an interlock that keeps it from going into reverse until the parking brake is released.  That is a long shot.  You would think that there would be an interlock on the forward gears as well, but these computers have strange algorithms.
Jim Shepherd
Evergreen, CO
  • steam nut
« Reply #20 on: January 03, 2011, 02:38:00 PM »
Have had A  bad battery screw ddec up. So prevost might have something. Could be a corroded terminal-fuse holder or loose connection. Do you have the 4 group 31 battery-thats what I had and one was bad when load tested.
Offline Don Fairchild
« Reply #21 on: January 03, 2011, 03:36:01 PM »
Jim;
After you get all the batts checked out build air so you can get under the bus. With the batts disconnected unplug all the conectors from the trans. Clean them good and put some dielectric greese on them and plug them back in. If that does not work take it out for a drive and see if you have a shift flairup in third or fourth gear. (engine rpm will go up but the bus will not pick up speed). Hope thats not it.
It may be a solinoid, but it should give you a code.
Bob ware as clifford suggested is a good source, we used to share ideas when I was building allisons at Delaney & Ahlf way back when. You might give dartco a call. I think their is a out let in orange county.
Hope that helps
Don
« Reply #22 on: January 03, 2011, 04:47:16 PM »
Jim, I spoke with Bob he said he thought Prevost used the output function relays on that bus he said check wires 112,114,125 and 132 see if you have relays on those wires one controls the reverse function and there should be a 15 amp fuse to supply power to the relays hope this helps
Offline Ace
« Reply #23 on: January 03, 2011, 05:27:54 PM »
It could be a simple tripped breaker. Has that happen on mine.
Ace Rossi
Lakeland, Fl. 33810
Prevost H3-40
  • Jim Shepherd
« Reply #24 on: January 07, 2011, 08:32:24 PM »
Jim, any resolution yet?
I was thinking about this yesterday and wonder if being stuck in the mud might have dislodged one of the connections.
Jim Shepherd
Evergreen, CO
« Reply #25 on: January 27, 2011, 09:21:45 PM »
Just curious if we ever found out the problem here?
Offline dougyes
« Reply #26 on: January 29, 2011, 10:53:05 AM »
Regarding the parking brake issue. Ours was sticking. Replaced a diaphragm and it's good to go.
Was the tranny issue solved?
  • Jim Shepherd
« Reply #27 on: January 29, 2011, 06:03:10 PM »
I wrote to Jim off-line and he said that he is bogged down by a bunch of other projects and it could be a month or two before he gets back to the bus.
Jim Shepherd
Evergreen, CO
« Reply #28 on: January 29, 2011, 09:00:24 PM »
Thanx Jim. I was just curious.
artvonne
« Reply #29 on: January 30, 2011, 07:42:38 AM »
  Man, thats like reading a really interesting story in a magazine, and half way through it says "continued in next months issue".
  In all seriousness though, is this transmission really $25K? Why so expensive??
