June 24, 2018, 04:12:46 AM
Author Topic: OEM floor removal??  (Read 5105 times)
Offline tarrfish
OEM floor removal??
« on: January 07, 2011, 12:28:27 PM »
I am just getting started on a MCI 1023A. I have removed most of the interior and am considering whether or not to put new plywood on the floor. I am wondering how large a job this would likely be and what would I be able to access for inspection and repair with the floor out. This bus has some rust around the rear escape hatch so I figure there must be more places that need attention. The floor seems sound so I don't know if it is worth the trouble to tear it out. Thanks for any advice.
Offline robertglines1
  • steam nut
Re: OEM floor removal??
« Reply #1 on: January 07, 2011, 12:35:14 PM »
if it's not soft to walk on put your time and $ toward next step. The area around the factory bath room and above drive wheels are usually the most prone to soft spots. these areas can be replaced without removing complete coach floor. If it is soft or flexes when you walk on a area out it goes.  Again do it your way that's what nice about this hobby.    would be a good idea to put where your from in profile ;you might be just around corner from one of us.   Bob
« Last Edit: January 07, 2011, 12:37:55 PM by robertglines1 »
Offline tarrfish
« Reply #2 on: January 07, 2011, 12:50:57 PM »
Thanks for the reply Bob. I'm from mid coast maine and the bus has spent most of its life on the east coast. David
Offline divinerightstrip
  • 1990 Le Mirage XL
    • getting there by bus
« Reply #3 on: January 07, 2011, 01:11:35 PM »
I'm with Bob. You'll know if it needs replacing. Chances are it will somewhere down the line, but if it ain't broke...
Not sure if you noticed my article in BCM about removing my floor. Not a terribly huge job, but I only did it because it NEEDED doing. The floor was spongy and springy to my step. I only ripped out the rear where the damage was and kept the front. Most of these buses were built to last, so chances are, your floor will be fine for quite a while.
FWIW,
DRT
The Bus Girl
Offline tarrfish
« Reply #4 on: January 07, 2011, 04:51:08 PM »
Thanks, I still need to get the tank out from underneath the rest room, so I'll get a better look there soon. (UHG) David
Offline Oonrahnjay
« Reply #5 on: January 07, 2011, 05:00:26 PM »
I found that there were a number of "small" soft spots in a few places where the floor met the walls.  Not good.  When I got the soft spots out, I didn't have much floor left so I took it all out.  Then I found that the air brake system was almost all gone -- everything that could be rusty was corroded badly.  I had to rebuild the system from the unloader valve to the wheel hubs -- that was much easier with the floor out (I also went from old technology - the emerg/parking brake was a big lever next to the driver and a 5/8" rod going to the rear wheels - to new; spring brakes on the rear, modern release valves, etc.).  There wasn't much rust on the chassis or the framework for the floor but I was glad to have the chance to paint the chassis and rebuild the floor support structure.  I probably overdid it -- my bus was built to carry 99 people and it was just fine with thin-gauge angle under 1/2" ply but I strengthened it a lot.
But as others said, it was a *big* job and one to be avoided if you can.
Bruce H NC USA
6-cyl, 4-stroke, Leyland O-680 engine
Offline Paladin
  • Dave Knight
« Reply #6 on: January 07, 2011, 05:22:29 PM »
I'm of the opinion that it really should be done for numerous reasons even though it is big and disgusting job and is ultimately up to the individual.
Every one of the MCI's that I've seen under the floors of has had issues under the floor beginning with the wood, it gets trashed. Mine was no different, the floor was fairly sound BUT under it was trouble. I not only found multiple pounds of hair, grime, junk etc but undiscovered rust ( I had to weld up new cross supports in a few places), issues around the lavatory area and a large hole in the air beam that I never would have seen unless uncovered though I suspected it.  Personally I'd hate to lay down wood, tile or whatever only to find out that I had to rip it up to repair rust, stench or an air beam leak that I didn't know about previously and you can only reach the leak from up top. The air beam repair alone made it well worth the time in my book. Somewhere here I have pictures of the hole and the repair. I can tell you right where you could look for a leak in yours since they appear to be somewhat common in MCI's at least.
To each his own and have at it either way I say but for me it was well worth the peace of mind to get it done and unfortunately I'd plan on it again if I ever did another bus, just a dirty job needing doing.
Craig (Gumpy) did his before I did mine and mine was pretty much a mirror image of his and maybe a little more.
As Craig said in his write up regarding the grime alone, "Personally, I wouldn't be able to sleep nights knowing it was down there just waiting for the chance to rise up against me! "
http://gumpydog.com/Bus/MC9_WIP/Structural/Floor_Removal/floor_removal.htm
Addendum: I forgot to mention that while you have the floor up is a great time to mount some solid anchoring points to steel for furniture etc. Weld them in now and you have good points to mount to later, I don't really trust wood floor anchors to keep heavy furniture from giving me a nasty headache in a emergency stop or roll over.  Also a good time to run extra wire chases or what have you.
« Last Edit: January 07, 2011, 06:47:33 PM by Paladin »
'75 MC-8   'Event Horizon'
8V71  HT740
Salt Lake City, Utah
Offline tarrfish
« Reply #7 on: January 08, 2011, 08:51:54 AM »
Thanks for the honest opinions, that is exactly what I am looking for. The link was very helpful as well. I will probably tear it out so I can repair any rust and replace worn or old parts. Thanks, David
Offline John316
« Reply #8 on: January 08, 2011, 11:16:02 AM »
I have mentioned this before, but here it is again.
Taking the old bathroom tank is easy. All you do (if it is like ours, which I'll bet it is), is take a hammer and big old prybar to the underside of the tank, which should be covered in fiberglass (with a layer of insulation underneath that). That shouldn't take more then seven to ten minutes to break the outer "purdy" casing off. Just knock a hole in it, and break it off. Just make sure you are wearing gloves, because that stuff can hurt.
At this point you should be seeing a stainless steel tank. There should be two straps holding the tank up. There is a bolt on each end of each strap, four total (like my math ;) ). Then there are several ways of getting it loose. I simply took my air impact wrench, with a long extension, and backed the bolts out of there (that might have taken 1.5 minutes to take the bolts out). Watch out, because the tank could fall, so make sure it is supported.
The other way is to cut the straps out of there with a grinder. Again, not a big deal.
I don't remember, but there might be a hose clamp connecting the "drop tube" with the tank. All in all, I found that part to be super easy. It was less then twenty minutes by the time it was out and in the junk pile.
FWIW HTH
God bless,
Offline Jriddle
« Reply #9 on: January 08, 2011, 11:35:07 AM »
FWIW HTH
God bless,
They are talking about the floor?
« Last Edit: January 08, 2011, 12:33:59 PM by Jriddle »
John Riddle
Wells NV
1984 MC9
Offline rwc
  • No longer will be Now AM
« Reply #10 on: January 08, 2011, 01:52:35 PM »
I have the entire floor out of my 102D3 and am glad that I took it out. The dirt and filth that is under the floor is unbelievable. Also it allows the cutting out of the chair rails so the the new floor will be flat. I will be putting in metal plates where I want to bolt down copilots seat and other furniture. Also will spray foam insulate all voids not needed.  I have found some surface rust that will be addressed before new floor goes in, none of it major but will give peace of mind having found and fixed it. My plywood was in good shape with no soft spots but the odor from be a passenger bus for so long will not come out.   Rod
Offline tarrfish
« Reply #11 on: January 08, 2011, 03:39:16 PM »
I started tearing into it this afternoon. Got the ramp out, the linoleum up and about 20% of the plywood. It was definitely a good choice as the fasteners are pretty rusty, and plywood had some water damage. I am surprised the plywood is so thin, I would have thought it would be at least 3/4". I will fix any corrosion I find and have a nice flat surface to work with. Thanks for the advice, David
Offline John316
« Reply #12 on: January 08, 2011, 04:03:57 PM »
Jriddle,
I was a tad OT, referring to this post. Sorry for not being clear.
On another side note, RWC, that is great that you have a D modal. There are just a couple of us that have them now.
God bless,
Offline Doug1968
« Reply #13 on: January 08, 2011, 05:36:32 PM »
Tarfish,
I am converting a 102A3. I am about a year into it and thought I would chime in on your question regarding removing the floor.Here are some reasons you would want to remove the old floor.
1) You cannot believe how filthy the ducting and all of the pockets under the plywood will be.
2) It allows you to remove the seat rails and install a thicker plywood that will give you a more solid floor.
3) The sheet metal over the wheel wells on my coach were rusted and ready to be replaced.
4) Like Paladin stated, it allows you to add plating into the bus structure for mounting things like the copilot seat.
5) If you pre-paint the bottom side of the plywood you have a nicely finished ceiling in each of your bays.
I used 1 1/8" tongue & groove plywood and it finished off very nicely and is very solid.
Good Luck, Doug
1986 MCI 102A3 - 8V92 - 5 speed
Vancouver, Washington
Offline Jriddle
« Reply #14 on: January 08, 2011, 07:14:43 PM »
No Harm No foul. Just LOL. I too thought getting the tank out was not to hard. I used big__ bar to get mine out. :)  ;) :D ;D
John Riddle
Wells NV
1984 MC9
