June 24, 2018, 11:34:09 AM
Author Topic: Which sewer hose is the best???  (Read 5620 times)
Offline jmblake
  • Jason & Martha Blake
    • Creative Custom Cabinetry
Offline Lin
  • 1965 MC-5a
Re: Which sewer hose is the best???
« Reply #16 on: February 02, 2011, 08:28:15 AM »
Gus,
When I got my bus it had one of those trestle type supports.  I have tried to use it several times, but find it to be a nuisance.
Offline txjeff
« Reply #17 on: February 02, 2011, 10:34:05 AM »
Thanks for the replies.
 Im not sure what might be causing the holes since I only use the hose to empty the tank once a day and dont leave any waste in the hose. Im thinking that mabe another source other than WM might fix the problem. Worst case I will use a vacuum hose off a portable toilet truck. ;D
jeff
73 MC-7combo
Brenham, Texas
Offline busing704
« Reply #18 on: February 02, 2011, 04:15:03 PM »
I went to Lowes and got a 8  ft plastic gutter cuting pipe is hard to do with the right tools. Cost I think was 6.00
Offline gus
« Reply #19 on: February 02, 2011, 04:23:18 PM »
Lin,
Yeah, mine are collecting dust in the bay! They not only don't work they are great for pinching fingers.
704,
Didn't know about those, probably much better than sawing PVC but, as I remember, it was not much of a job. What I actually used was some green fibrous stuff that is probably for foundation drain systems. It is not as heavy as PVC but PVC is not hard to cut with a coarse toothed saw.
Offline steve wardwell
  • 73 MCI 7 8/71T combo just happy to be here
« Reply #20 on: February 02, 2011, 08:27:02 PM »
run the PVC down the tablesaw for a nice swale............any time I can I use 40 ga PVC with the rubber cuplings w/hose clamps ....I'll put a flex hose connector on the tank and it will fit into a 90 deg PVC..I have each end setups and rarely need to cut them down    .I tend to have several different lengths pipes and PVC joints,90s.45s glue and a saw handy.. used to fill in the correct leanth for the middle.....once in a great while I'll get a new 10'
Sometimes the more I think about something the less I think about something.    As soon as I save a little money my bus finds out.                                      Why grab a plane when you can take the bus ?                         If I'm wrong 10% of the time how can the "Queen" be right 100%
