Author Topic: MC5 B - again...  (Read 12142 times)
Offline RJ
Re: MC5 B - again...
« Reply #30 on: March 24, 2011, 10:46:16 PM »
Paul -
How ya gonna get it up your driveway?   ???
(Sorry, couldn't resist!)   ;D
RJ Long
PD4106-2784 No More
Cheney WA
artvonne
« Reply #31 on: March 24, 2011, 11:32:28 PM »
Paul -
   I plan to drive it up here.  ;D
Offline bevans6
  • 1980 MCI MC-5C
« Reply #32 on: March 25, 2011, 04:58:10 AM »
Is it an automatic or a 4 speed?  I missed that part.  8V71? Jake brake?
If it was Mel Tillis' bus it might have had "there goes M-Mel" on it because he apparently stuttered...
artvonne
« Reply #33 on: March 25, 2011, 03:46:09 PM »
  Its a 4 speed.
  Just got an email from Mel, lol. I found his website and asked about the bus in an email.
  He says no, never owned an MCI, says he always bought Golden or Silver Eagles. Oh well, I got an email from Mel out of the deal.
artvonne
« Reply #34 on: March 27, 2011, 10:59:35 PM »
  Integral PS?
  The steering gear has lines going to it, but a ram above the steering rod connected to the pitman arm.
Offline bevans6
  • 1980 MCI MC-5C
« Reply #35 on: March 28, 2011, 03:46:51 AM »
That ram assist is the stock power steering on a MC-5B.  The integral steering has the power steering lines connected to the steering box itself.  That came in, on MCI's, around 1983 so no MC-5's had it stock.  Mid model MC-9's were the earliest with integral steering stock.
artvonne
« Reply #36 on: March 28, 2011, 08:59:31 AM »
  Thats whats confusing me, there are lines going to the steering gear, but it still has a ram.
Offline rgrauto
« Reply #37 on: March 28, 2011, 09:04:05 PM »
There is a control valve mounted to  the gearbox that controls fluid pressure flow to the hyd. cylinder , HTH,   Glen
artvonne
« Reply #38 on: March 29, 2011, 07:32:59 AM »
  How bad is the the OE system?
  Can anyone lead me to a site that explains conversion?
  Bus 101 shows putting an integral gear into an MCI 8 or 9, would this be simular??
Offline lostagain
  • MC5C
« Reply #39 on: March 29, 2011, 07:51:41 AM »
Paul,
the OE power steering with the ram assist is OK, but not nearly as tight and precise as an integral power steering. This is why a lot of buses of that vintage were converted. The MC5A,B or C is very similar to the 8 or 9, so your info on Bus 101 would be relevant.
JC
JC
Blackie AB
1977 MC5C, 6V92/HT740
artvonne
« Reply #40 on: March 29, 2011, 08:22:51 AM »
Paul,
JC
  I assume by things ive seen and read that there is no direct replacement gear, that any gear I find would have to come from a large truck, and I will have to custom fit the gear just at I see on the Bus 101 site???
Offline bevans6
  • 1980 MCI MC-5C
« Reply #41 on: March 29, 2011, 08:47:10 AM »
You can either engineer a new, unique setup yourself or duplicate the installation of the steering box on a MC-9.  Mine is the same as a MC-9.  You also have to change the power steering pump pressure to 2000 psi.  The ram system uses 1000 psi, and you really can't  turn the wheel unless you are rolling with that pressure.
artvonne
« Reply #42 on: March 29, 2011, 09:34:43 AM »
  Was the -9 gear a direct bolt in?
Offline Busted Knuckle
« Reply #43 on: March 29, 2011, 09:49:10 AM »
NO! Here is a good source to call and get the info needed or to even have them do it as they are experienced and have the parts on hand!
http://www.caylorsupply.com/bus-repair.html
artvonne
« Reply #44 on: March 29, 2011, 10:30:27 AM »
  Thanks. I gave them a call, looks like $900 for a kit. The more questions I ask, the more I realise I really need an operators/service manual.
