June 23, 2018, 10:19:54 PM
Author Topic: MCI motor mounts  (Read 3399 times)
Offline Tom Y
MCI motor mounts
« on: April 02, 2011, 10:58:37 AM »
Does anyone have a source for a softer motor mount (Other than stock)? I have a 5C and would like to see if I can get some vibration out at idle. Thanks Tom Y
Tom Yaegle
Re: MCI motor mounts
« Reply #1 on: April 02, 2011, 11:08:49 AM »
Tom, go to marine engine mounts I use the Dual/Flex find their site on the web and it will have your engine a little pricey but they are nice and sorry I forgot the link but will look it up for you if you don't find ot
Offline Tom Y
« Reply #2 on: April 03, 2011, 05:32:55 AM »
Clifford, Do you think the Dual Fex will remove more vibration? I will see if I can find them, if not I'll get back to you.  Thanks Tom
Tom Yaegle
Offline Tom Y
« Reply #3 on: April 03, 2011, 05:44:25 AM »
Clifford, I see a lot of places to buy. But not the MFG. Do you know who makes these? My other concern is if these are meant for something other than a boat? I can see me running into something and the motor now sets beside the driver? Thanks Tom
Tom Yaegle
« Reply #4 on: April 03, 2011, 06:58:52 AM »
Tom says on the box www.bushingsinc.com I just looked and they have a listing for all marine engines with weight and size
« Last Edit: April 03, 2011, 07:03:08 AM by luvrbus »
Offline bevans6
  • 1980 MCI MC-5C
« Reply #5 on: April 03, 2011, 12:41:51 PM »
Does your installation of the L10 use the stock MCI  motor mounts?  Front and rear?  Just curious how you did it.
Offline Tom Y
« Reply #6 on: April 03, 2011, 06:13:42 PM »
I made the mounts and used the(used) MCI rubbers. I replaced them a couple years ago, with new. I had the motor out this weekend and started thinking about trying  something else.  Tom Y
Tom Yaegle
Offline Brian Diehl
    • www.brihil.com
« Reply #7 on: April 04, 2011, 07:38:27 AM »
Tom, why did you have the motor out?
Offline bevans6
  • 1980 MCI MC-5C
« Reply #8 on: April 04, 2011, 09:41:24 AM »
The guys who put series 50 engines in MC-8's and 9's have some soft motor mounts to accomodate that shaker.  Look for some S50 motor mounts and see if you can adapt them.  The 8v from the MC5 is very smooth compared to a 4 cyl engine.
« Reply #9 on: April 04, 2011, 10:07:03 AM »
Most of the guys with series 50 and 60 do use the marine mounts
Offline Tom Y
« Reply #10 on: April 04, 2011, 12:48:39 PM »
Brian, That's another topic.  But I am changing transmissions.
I am not sure I want to spend a few hundred on motor mounts right now, and i know my wife doesn't.  Tom Y
Tom Yaegle
Offline mikelutestanski
  • Mikes Metal Mistress
« Reply #11 on: April 04, 2011, 04:57:54 PM »
Hello
      Can you get the standard mci rubber mount bushings anymore?. I had trouble when I installed the L10   but I had a set of the rubber ones leftover from a previous job.  I used the rubber 892 bushings for the front of the engine. I only could get the polyurethane  rubber mounts..
    If you have a source for the old style rubber mounts let me know.
  thanks and regards  mike
  1972 MCI 7
  L10 Cummins  B400R  4.625R
Offline Chopper Scott
  • MCI 7
« Reply #12 on: April 04, 2011, 05:37:23 PM »
I've had to do some strange things with Cummins irrigation motors (industrial). The earlier ones would shake everything apart. I didn't change anything on the motor but had to seperate things that generally are attatched to it.
« Reply #13 on: April 04, 2011, 06:01:45 PM »
Yep the L10 Cummins can dance on the same floor with a series 50 when it comes to vibration on my L10  Cummins engines in the service trucks Cummins changed the vibration damper every 2500 to 3000 hrs or they would shake lights off a truck
Offline Jaime
« Reply #14 on: April 04, 2011, 10:54:58 PM »
Just as a thought I thought I would might mention that on my 5a when I lost my fan belt I could not fell the engine run, turned out that all the vibration I was feeling was being caused by a bad pulley on the fan drive. after replacing pulley I had very little but more than with out the fan belt.
