On the other hand, pop-riveting aluminium to stainless steel as a structure on the underside of the bus and then driving it in the winter with road salt is a sure-fire way to be doing that repair again soon...Brian
... possible corrosion caused by attaching alum directly to mild steel or stainless? Should it be separated by a mechanical barrier or will paint do? What kind of fasteners?
The stainless/aluminum thing, if its so bad, why do all the outboard boat engines use stainless steel bolts??
Somewhere on that outboard engine you will also find a hunk of zinc, known as a "sacrifical anode." -Sean
Zink Chromate is not worth crap any longer,,, EPA mandated the ZINK removed, so now is junk.>>>Dan
(snip) How about a discussion on possible corrosion caused by attaching alum directly to mild steel or stainless? (snip)
Just an interesting side note. I have two 35hp Elgin outboards from 1958 that were positive ground.
... I also know what plain steel and iron bolts will do in an aluminum casting. ... Not saying that chemically they belong together, just saying ive never seen it be problem like iron is with aluminum.
