June 23, 2018, 06:06:00 PM
Author Topic: mci 9 fuel gauge  (Read 2515 times)
Offline tony
  • I HAVE A 1980 MCI
mci 9 fuel gauge
« on: May 10, 2011, 01:05:48 AM »
how do you know how much fuel you have no gauges for fuel 1980 mci 9
Offline Chopper Scott
  • MCI 7
Re: mci 9 fuel gauge
« Reply #1 on: May 10, 2011, 01:12:07 AM »
I have a stick... :D ;D Actually it is a piece of rubber hose that I dip into the tank and pull back out. In all reality I have heard that those with gauges have ended up low on fuel and stranded but us "dippers" seldom encounter that problem. I start worrying about fuel after the first 100 miles!! After 500 miles I am a nervous wreck and stop and put 75 gallons in my 144 gallon tank! Actually I don't have an odometer either so now I'm really nervous!!
Offline robertglines1
  • steam nut
« Reply #2 on: May 10, 2011, 01:21:11 AM »
Isn't there a low fuel buzzer/light? My 8 had one. or was that a option?  Bob
Offline belfert
« Reply #3 on: May 10, 2011, 01:26:19 AM »
I replaced the float type sender in my bus with a capacitance based sender with no moving parts.  It is quite accurate.  My VMSpc shows total fuel used and the fuel gauge tracks right along with it.
I know from experience that I can only use 130 gallons out of my 150 gallon tank.  My sender is cut off so that empty is at or just above 130 gallons.
Offline babell2
  • Brice
    • My bus Blog
« Reply #4 on: May 10, 2011, 01:42:36 PM »
The only thing to watch with the capacitance senders is they are susceptible to fungal shorting. Be sure to BIO your tank every now and again.
Brice
1980 MCI-9 "The Last Resort" Located just south of Atlanta GA.
Just starting conversion. A long way to go!
The other Brice
Offline buswarrior
  • '75 MC8 8V71 HT740
« Reply #5 on: May 11, 2011, 03:03:34 AM »
Hello tony.
In the old daze...
Coach was fueled daily, no fuel gauge required.
You may add the fuel gauge sender to one of the plates on the end of the fuel tank, and a gauge in the dash, or you may just keep track of your mileage. MCI sells the sender and the gauge to go in one of the holes in your dash.
Safe fuel range for your coach would have been considered to be 500 miles or so.
Any MCI with no gauge came with the low fuel warning, but you are on the verge of no fuel when it comes on, so best to have a better way of finding out...
Busnuts are best to keep the tank full when parked, to keep the condensation to a minimum.
