June 25, 2018, 07:43:15 AM
Author Topic: What do folks use to clean oil off engines?  (Read 6003 times)
Offline belfert
« on: June 25, 2011, 06:50:32 PM »
I have lots of oil all over the side of my engine from two oil leaks.
What is the best product to remove this oil?  Bryce (BK) used brake cleaner to remove oil when he fixed an oil leak on my engine at his place a number of years back.  My only worry about brake cleaner is that it removes paint.  I would prefer not to use something that has to be rinsed off as that makes a mess for working on the engine.
Offline thomasinnv
  • Derrick Thomas
Re: What do folks use to clean oil off engines?
« Reply #1 on: June 25, 2011, 06:53:26 PM »
oil eater is the best i have found. it is gentle on hoses and paint, but tough on oil. cleans up really nice, you could almost eat off it after you clean it.
1998 MCI 102-DL3
Series 60 11.1/Alison B500
Offline blank
« Reply #2 on: June 25, 2011, 07:13:58 PM »
 Ive tried about everything, but mineral spirits and elbow grease has worked better than anything. Someone a while back mentioned using Armorall, then wash down with windex, said the two compound each other. Never tried it, but im going to, sounds like it just might work.
  Be careful with pressure washers, while they are great at removing heavy grime, they can blow out gaskets, push water past seals, strip off paint, destroy soft hoses, push water inside electrical components, flood the engine, etc..
Offline Cary and Don
« Reply #3 on: June 25, 2011, 07:28:09 PM »
The best thing we have found is the cleaner they use just before applying new paint on a vehicle.  There may be other brands, but the one we have been using is Acryli-clean.  Won't hurt the existing paint.  Just scrape off the big stuff and wipe down with the cleaner.  Bad news,  $30 a gallon and California is banning it as of the first of the month.
Don and Cary
1973 05 Eagle
GMC 4107
Neoplan AN340
1973 05 Eagle
Neoplan AN340
Offline bergdoll
« Reply #4 on: June 26, 2011, 04:33:02 AM »
while in the army, we used diesel to clean our engines. toilet brush & diesel. worked very well.
1982 Prevost Champion/Marathon under construction...
Offline belfert
« Reply #5 on: June 26, 2011, 05:43:41 AM »
My plan is to buy some Oil Eater at O'Reilly.  I need to buy an external torx socket anyhow.  I may try the mineral spirits.
I'm not going to use diesel as it tends to attract dirt unless you use another degreaser to remove the diesel residue.  I operated a diesel riding mower in college and it had dirt all over the fuel tank from diesel spills.
Offline trucktramp
« Reply #6 on: June 26, 2011, 06:16:37 AM »
I had some stuff that I think I got from Sam's Club or one of those "Warehouse" places.  It was called Simple Green.  I never used it as a degreaser but my boy claims that it worked great and was suprisingly gentle as he used it as the soap to detail carpets in cars.  I don't know if it is still around though, I bought it several years ago.
You might try Dawn dish soap.  It's what the EPA uses to clean crude oil off of waterfowl and that stuff is like tar.  Or try starting fluid.  It will take off the oil but be careful around any open fires.  Just a thought.
Dennis Watson
KB8KNP
Scotts, Michigan
1966 MCI MC5A
8V71
Spicer 4 Speed Manual
Online luvrbus
« Reply #7 on: June 26, 2011, 06:20:11 AM »
You don't want to use the Simple Green or the Purple stuff around or on wiring will cause you some problems later fwiw
Offline Ace
« Reply #8 on: June 26, 2011, 06:27:18 AM »
Why?
Ace Rossi
Lakeland, Fl. 33810
Prevost H3-40
Online luvrbus
« Reply #9 on: June 26, 2011, 06:34:28 AM »
 Corrosion at the connections Ace the stuff has a acid in it or did,spray it on aluminum or bare copper and check in a week
« Last Edit: June 26, 2011, 06:42:06 AM by luvrbus »
Offline babell2
  • Brice
    • My bus Blog
« Reply #10 on: June 26, 2011, 07:00:36 AM »
I have my bus in a storage lot on gravel. I have used multiple products to de grease the engine and trans. My bigest concern is the oil slick forming under the bus. It is hard to catch up on 30 years of accumulation.
Brice
1980 MCI-9 "The Last Resort" Located just south of Atlanta GA.
Just starting conversion. A long way to go!
The other Brice
« Reply #11 on: June 26, 2011, 08:37:17 AM »
Oil Eater has already been mentioned-but it works so well-I'm saying it again.  Oil eater is THEE BEST degreaser I've EVER found!!! In 10% with 90% water-I wash my bus with it.  On really grimy spots I just spray 50/50 mix from my pump bottle-and presto it is gone.  I use a 50/50 blend to clean my carpet inside the bus (always seem to track grease in somehow). My wife uses a 50/50 blend to degrease my clothes.  I use a 25% blend to clean the grease in the kitchen.  And on and on it goes.  I don't use anything else.  Fantastic, 409, Simple Green are all like water in comparison.  You can order it online.  Good Luck, TomC
Offline belfert
« Reply #12 on: June 26, 2011, 08:49:24 AM »
I already bought a gallon of Oil Eater at O'Reilly this morning.  I also picked up a couple of spray bottles to mix it 50/50 with water.  I wanted a spray bottle as a gallon might last the rest of my life and I'm not that old.
Offline belfert
« Reply #13 on: June 26, 2011, 01:16:38 PM »
Either I'm doing something wrong with the Oil Eater, or this stuff is plain worthless.
I mixed up a 50/50 solution in a spray bottle and let it soak for about 5 minutes.  When I wiped it after 5 minutes hardly anything came off.  I soaked it down real good and let it sit at least 30 minutes this time.  Still hardly anything came off.
In some areas the oil is caked on 1/4" thick.  I scraped as much as I could off and the Oil Eater still didn't help.
Offline Chopper Scott
  • MCI 7
« Reply #14 on: June 26, 2011, 03:06:47 PM »
Pretty hard to beat a pressure washer. One does have to use some common sense however. I used mine today cleaning off some areas in fact. I wish I had a steam cleaner. Those babies really get stuff clean. Warning however...... I stated common sense is involved. If you direct the pressure towards your rearend in may not be wise!! ;)
