BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
Air or Electric Wiper Motor
« previous
next »
Print
Pages: [
1
2
All
Go Down
Author
Topic: Air or Electric Wiper Motor (Read 14759 times)
Tikvah
Hero Member
on:
September 22, 2011, 04:37:12 AM »
I snapped one of the shafts of my air wiper motor. Now I need to replace the motor. I've heard there is an electric replacement for these air units.
Am I better off to go with electric? Where do I get a replacement, air or electric? Any experience?
Dave
Logged
1989 MCI-102 A3
DD 6V92 Turbo, Alison
Tons of stuff to learn!
Started in Cheboygan, Michigan (near the Mackinaw Bridge). Now home is anywhere we park
http://dave-amy.com/
Hero Member
Re: Air or Electric Wiper Motor
Reply #1 on:
September 22, 2011, 05:25:33 AM »
Modern cars don't have air or vacuum wipers anymore. With air you have to worry about bad valves, air leaks, and bad seals.
Autex (
www.autexacs.com
) makes electric retrofit kits for many models of buses
Logged
Joe Camper
Hero Member
Reply #2 on:
September 22, 2011, 05:28:54 AM »
Been there, still there, and never solved the issue.
No good solutions IMHO
If you go to electric you should need some kind of transmission (linkage) to connect both sides together. Prevo has a kit for electric conversion it is way way expensive.
The alternative is stay with air that is also pricey itself and performance is terrible.
I have hoped a common motor from a bone yard would make a suitable replacement and then I would simply buy 2 and run them separate off 2 switches to eliminate the linkage project...........but I have not persued that yet.
Someone had some conversion kits for sale or had a source for them and I think it was here. I had reason why i did not go that route but forget why. I think cost of those too
Logged
Hero Member
Reply #3 on:
September 22, 2011, 05:35:42 AM »
AM Equipment in Or I believe the kit is little over 600 for the electric conversion for a MCI
Logged
Tikvah
Hero Member
Reply #4 on:
September 22, 2011, 05:43:54 AM »
I remember driving school bus years ago and they had electric wipers, on separate switches. I think linkage would be too difficult, but also a lot of strain on one motor.
Logged
1989 MCI-102 A3
oldmansax
Hero Member
Reply #5 on:
September 22, 2011, 05:44:53 AM »
every truck I ever owned had air & the MCI has air. Keep 'em maintained & I don't have any problems.
TOM
Logged
1995 Wanderlodge WB40 current
1985 Wanderlodge PT36
1990 Holiday Rambler
1982 Wanderlodge PT40
1972 MCI MC7
Joe Camper
Hero Member
Reply #6 on:
September 22, 2011, 05:47:34 AM »
I just called the link posted in this thread its 750 for the Prevo one.
On our bus the square mounting plate on the front of the bus that the post goes thru that the arm attaches to has screw fasteners that are FROZEN SOLID. This was another issue for me. If those panels have to be removed I will need to grind off the heads drill out the screws and re tap the threads for every single screw I could not get even 1 of them to budge.
I can access those motors relatively easily from inside the bus but never found out if I could do the change completely without having to pull the outside access off.
I think it is safe to say sticking with air would be the easier and less expensive alternative.
Logged
Hero Member
Reply #7 on:
September 22, 2011, 05:58:40 AM »
My Dina has separate electric motors for each wiper. I can control each wiper individually for high and low constant speed. For intermittent wipers there is one switch for both wipers. I would have thought all buses with electric motors would have two motors.
Logged
artvonne
Guest
Reply #8 on:
September 22, 2011, 06:15:11 AM »
Quote from: belfert on September 22, 2011, 05:25:33 AM
And your point? Airplanes still use Magnetos and vacuum powered flight instruments so they will still function after a complete electrical failure. The most common failure ive seen in vehicles is electrical, and on road trips its common to see the battery or alternator fail. Reading these Bus forums I see a lot of the same thing. The more systems we have that dont require electricity, the farther we can run down the road after the alternator goes south. That some of these old Buses are 50 or 60 years old and the pneumatic wipers still work should be enough to have some faith in them.
All the Buses Ive seen with air wipers have dual air motors with seperate controls. And they are vernier, in that you can turn the knob to any speed you want infinetly. So slow its every bit like intermittent.
Logged
Hero Member
Reply #9 on:
September 22, 2011, 06:22:51 AM »
Electric wipers are far better than air but like Joe said you still have the linkage even the air has 2 motors,direct drive electric wiper motors are available but at a premium price and they have a clutch instead of linkage
Logged
lostagain
Hero Member
Reply #10 on:
September 22, 2011, 06:30:51 AM »
Air wipers work very well. It takes a little maintenance once in a while to keep them reliable. Air wipers are part of what makes a bus a bus.
JC
Logged
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
bobofthenorth
Hero Member
Reply #11 on:
September 22, 2011, 06:44:51 AM »
IMO the best two changes I made to the frenchy-bus after we bought her were a King Cruise and changing the wipers to Autex electrics. But I'm sorry to say you absolutely have to get those plates off the front in order to do the swap.
Logged
R.J.(Bob) Evans
Joe Camper
Hero Member
Reply #12 on:
September 22, 2011, 06:53:48 AM »
LOL you have a 4 year older bus than us. Used up the entire weekend uh. Welcome to the world of Prevo ownership
It is also up above the paint line so I would need to be careful about that aspect too. I do not see it happening any time soon.
What is a King Cruise.
Logged
bobofthenorth
Hero Member
Reply #13 on:
September 22, 2011, 07:29:27 AM »
Quote from: Joe Camper on September 22, 2011, 06:53:48 AM
Brand of cruise control.
Logged
R.J.(Bob) Evans
Hero Member
Reply #14 on:
September 22, 2011, 08:30:37 AM »
While my older '85 Kenworth and my '77 AMGeneral bus has air wipers (the AMGenerals are going to be changed) I don't know of any commercial vehicle that are still using air. All are electric now-and use just one electric motor for both wipers. Good Luck, TomC
Logged
Print
Pages: [
1
2
All
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
