Author Topic: What is this?  (Read 2824 times)
Offline Mex-Busnut
What is this?
« on: October 25, 2011, 05:58:52 PM »
Dear Friends,
This is fed from some wires from my alternator. Is this the voltage regulator? If so, I assume the small hole might be a pot for voltage adjust?
Does anybody have an idea, schematic, etc for this?
Thanks in advance!!
Jake brakes
Online Brassman
Re: What is this?
« Reply #1 on: October 25, 2011, 06:29:08 PM »
Do you need schematics for the innards? The rest you already know.
Offline Mex-Busnut
Re: What is this?
« Reply #2 on: October 25, 2011, 06:38:55 PM »
So you are affirming it is the voltage regulator?
Yes: I would love a schematic of its innards!
Thanks!
Jake brakes
Online Brassman
Re: What is this?
« Reply #3 on: October 25, 2011, 07:10:19 PM »
Yes to the voltage regulator affirmation. As for a schematic, you could just open it up and look.
Offline roadrunnertex
Re: What is this?
« Reply #4 on: October 25, 2011, 09:34:57 PM »
It,s a Delco Remy Voltage regulator.
Voltage setting should be close to 27.2 volts.
Inside you will find a printed circuit board.
Three terminals Positive Negative and Field.
The above information is from a MC-9 maintenance manual dated 1-1-89
Hope this helps.
jlv
Offline baker4106
Re: What is this?
« Reply #5 on: October 26, 2011, 06:21:25 PM »
If that regulator is off a 4104 or 4106 then 27 volts is too high
artvonne
Re: What is this?
« Reply #6 on: October 26, 2011, 06:45:04 PM »
  Are any of the 24 volt regulators mechanical?
Re: What is this?
« Reply #7 on: October 27, 2011, 07:40:30 AM »
When I replaced my Delco 50DN with a rebuilt one, I also replaced that huge transistorized regulator with a digital one.  The digital regulator is about the size of a deck of cards and still has an adjustment screw for voltage.  My electrical system still surges up and down voltage wise, but noticeably less. 12v system should be adjusted to 14.1v. 24v double that. Good Luck, TomC
Offline Mex-Busnut
Re: What is this?
« Reply #8 on: October 27, 2011, 08:12:51 AM »
Thanks to all for your enlightening replies!
Blessings!
Jake brakes
