June 23, 2018, 06:44:28 AM
Author Topic: 3000 Mile Trip - Bus Did Fine - But.....  (Read 6868 times)
Offline rv_safetyman
  • Jim Shepherd
    • Bus Project Details
« on: October 26, 2011, 08:14:09 PM »
I thought that I would post a story about a successful trip, since we often hear about the "bad" trips.
This trip covered close to 3100 miles and we were on the road 41 days.  The bus performed very  well.  We had one minor incident in IA where the charge air cooler hose came off.  It took about 15 minute to get it secured back in place.  Other than that, we had no problems.  I take a lot of time to do preventative maintenance, but part of the success is just plain dumb luck.
Like others, I have replaced all of the engine components that tend to wear out and carry some parts with me.  That all costs a bit of money, but it gives me a better feeling.
The Series 60 and Autoshift is a dream to drive.  This second engine is set at 500HP and 1650 foot pounds torque.  We weigh about 46K with the service truck and it is nice to have that power in the mid-west rolling hills.  Makes passing slower vehicles much easier.
We spent a lot of time in IA (relatives), OH (genealogy) and TN (Bus Conversions Rally).  We got to see some pretty good fall colors and the weather was not all that bad (got down into the low 30s a few times, but we were comfortable.
Now for the but.....
As most of you know we tow a rather heavy service truck behind the bus.  About a mile from the house, the hitch broke and the truck swerved from side to side quite a bit.  It could not have happened in a worse spot, as the truck swerved into the ditch and the right front wheel hit a big rock and tore up the front end pretty good.  I lost a tire, a high dollar aftermarket wheel and at least two of the control arms.  It is snowing here right now (got home just in time), so I can't inspect for further damage.  My guess is that it will be several hundred dollars to repair – with me doing the work.  Long ago, I converted to very robust safety chains, and that kept the truck from breaking away from the bus.
I had just added an item to my to-do list to carefully inspect all of the towing components this winter.
Jim Shepherd
Evergreen, CO
Re: 3000 Mile Trip - Bus Did Fine - But.....
« Reply #1 on: October 26, 2011, 08:33:47 PM »
Might consider double clamping the charge air cooler hoses since the Series 60 (especially the 500hp version) runs at a high turbo boost.  Good Luck, TomC
Offline bobofthenorth
    • R.J.(Bob) Evans
« Reply #2 on: October 26, 2011, 08:41:42 PM »
Glad to hear you made it home without putting the Eagle on a hook Jim.  We're back over in Nebraska for a while so could you please keep that snow over there next to the mountains?  Thank you very much.
R.J.(Bob) Evans
My website
Our weblog
  • Jim Shepherd
« Reply #3 on: October 26, 2011, 08:48:33 PM »
Tom, I think the issue was that there are a couple of fairly long lengths that are not supported well.  I thought I had done that part properly, but now I am not sure.
That said, I have blown off a hose or two in other places.  Everything has a bead, but I think the that the silicone flows under the clamp (even spring clamps).  I tightened all the clamps I could get to and they were all slightly loose.  A good friend (hardheadedken) sent me some extra clamps and I just have to find the time to double clamp everything.
Kind of sad - I don't know what our next trip will be.  We won't make quartzsite (conflict) and we have quit doing tradeshows (had to stop the bleeding in this terrible market).  We need new rear tires and we might have to wait until we hit the loto to travel again ::)
Jim Shepherd
Evergreen, CO
  • Jim Shepherd
« Reply #4 on: October 26, 2011, 08:51:57 PM »
Bob, we can't promise anything.  Our weather forecasters predicted 20 inches at our altitude.  Not likely that will happen.  Almost non-stop coverage this morning.  Must have been a slow news day.
I think I heard that it will turn to rain on the plains.
Supposed to be in the 60s this weekend here.
Jim Shepherd
Evergreen, CO
Offline Sean
  • Geek.
    • Our Odyssey
« Reply #5 on: October 26, 2011, 09:18:35 PM »
Jim, so glad to hear you made it safely and that your mishap was not worse, as it easily could have been.  It was great seeing you guys here in Chattanooga (yes, we're still here) and we look forward to the next visit, whenever that may be.
  • Jim Shepherd
« Reply #6 on: October 26, 2011, 09:33:37 PM »
Sean, good seeing you as well.  Always enjoy our visits.  Next time I hope we will get to see Louise as well.  I read your latest blog and that whole bearing situation is a real bummer.
Jim Shepherd
Evergreen, CO
Offline RnMAdventures
« Reply #7 on: October 26, 2011, 11:48:37 PM »
Jim, it was refreshing to read about your successful trip. We had a series 60 in a compressor once and it ran for weeks nonstop without a glitch. I was really impressed with it and wondered how it would be in a bus.
Mike & Rosemarie
1964 PD4106-2626
DD8v71 & Allison v730
  • Jim Shepherd
« Reply #8 on: October 27, 2011, 12:50:59 AM »
Mike of the Series 60 is pretty popular in buses - both as an OEM installaton and as a conversion.  Most people feel that it is a great engine.
Unfortunately, this is my second Series 60.  The first one had a bit less than 700k and I think it had been ridden hard and put away very wet.  Got about 55K before the engine got pretty bad (two liners sank in block and caused in a lot of damage).
Most folks will tell you that they are a million mile engine.  Statistics and my experience suggest that does not always happen.  This engine was rebuilt by DD about 250K miles ago.  I have the receipts and maintenance records thanks to a great DD dealer and truck owner.  Hopefully it will last the rest of my life :o ;D
This engine really pulls strong (last one was pretty puny).
To top it off, I get over 7 MPG.
Jim Shepherd
Evergreen, CO
Offline RJ
« Reply #9 on: October 27, 2011, 04:20:51 AM »
Jim -
Glad you made it home safely with an "interesting" experience to add some color to your journey.  Most importantly, nobody got hurt!
Could you elaborate a little more on "the hitch broke?"
What component(s) are you talking about?  Maybe some pics?
Since a lot of folk tow something, more info can be helpful preventing a similar event for another busnut.
RJ Long
PD4106-2784 No More
S13406 1978 MC-5C Converted
6V71/MT-644
S14947 1980 MC-5C Shell
6V92/HT-740
Cheney WA
Offline technomadia
  • Zephyr - 1961 GM PD-4106-446
    • Technomadia
« Reply #10 on: October 27, 2011, 05:27:20 AM »
Glad to hear you guys made it back home, Jim.. it sure was a pleasure to meet you and Pat in Chattanooga and hang out at Choo Choo!
So sorry you encountered a problem with the hitch so close to home.  We too are curious for more information on what happened and what might have prevented it (when you have a chance to assess it, of course). As you know, we're about to add a tow behind vehicle to our bus, and trying to do it as right & safe as possible.
Warm wishes to you and yours,
 - Cherie
Offline blank
« Reply #11 on: October 27, 2011, 11:30:44 AM »
Jim -Could you elaborate a little more on "the hitch broke?"
  As others, glad your home safe. I too am interested what broke exactly, something on the towed, or the hitch on the Bus?
  Good thing when stuff breaks "after" were home, rather than early on. Or in a bad place. If its going to break I mean.
  • Jim Shepherd
« Reply #12 on: October 27, 2011, 12:35:57 PM »
Ok folks, this is embarrassing and painful to write.  The part that broke is a part that I made.  It is shown in the photo below.
Part of the reason it is embarrassing is that I wrote an article for BCM on towing safety (March 2010).  The main thesis of that article was the rather poor protection offered by the cables and connecting hardware which come with the tow bars. In the article I talk about the relative strength of cables and various qualities of chain.  I also discussed the rather poor quality hardware that can be found in flea markets and most hardware stores.  I used top quality chain and connecting hardware.  That part worked very well.
I have 5/16 grade 70 (DOT approved) chain to connect the bus and the truck.  I also have a supplemental chain (3/8 grade 70) that is connected to the engine rails and the tow bar (you can see that in the photo).  The supplemental chain is in place to prevent a separation of the bus and toad in the event of a failure of the bus trailer hitch.  I am really glad that I had gone the extra mile with the safety chains, as I doubt that the cables that came with the tow bar would have held.
Now about the part that failed.  Tow bars must be level (parallel to the ground).  I built the adapter shown in the photo in order to raise the receiver for the tow bar.  The lower tube that inserts into the bus receiver is standard wall tubing.  This is the same tubing typically used in commercial trailer ball adapters.  That is the part that failed.  It broke off right at the bus receiver.
In hindsight, I should have used at least 1/4 inch wall tubing.  The standard tubing is probably OK for normal towing where the forces are mostly horizontal.  In my case, I have a pretty good bending moment on the tube due to the rise in part.  Every time I started or stopped, the horizontal load tried to bend the tubing going into the bus receiver.  Over time, the part fatigued.
Rookie mistake made by an engineer with way too much experience - experience that should have kicked in when I made the part.
Jim Shepherd
Evergreen, CO
Offline blank
« Reply #13 on: October 27, 2011, 12:54:00 PM »
  Well, you could have said something much simpler, and shirked responsibility like most everyone else does. Its a bigger man that can admit his shortcomings.
  I can weld, and ive gotten "okayish" at it over the years, but I still dont like welding anything that which it breaking could hurt anyone. Ive seen way to many things people with way more schooling and experience had break (bridges, space vehicles, wings seperating from airplanes), a mans gotta know his limitations.
  So like you, I compensate by beefing up other areas, and adding extra safety, like your additional chain. Then im out driving around and see some idiot pulling a trailer with the trailer chains not hooked up, the lights not hooked up (or not working), carrying some big piece of equipment like an excavtor or skid loader (or a Cat), and its not chained down either. Going through Des Moines last year, a Skid Loader came off a trailer and was sitting in the freeway under an overpass and someone hit it. There just isnt any excuse for that kind of BS. Some clown up in Minnesota, years back, had a big Cat on a lowboy semi, (BIG CAT/WIDE LOAD), just moving it a mile to another site, didnt chain it down. Stopped at a light, Cat rolled up and over and squashed him dead. At least hes out of the gene pool.
  • Jim Shepherd
« Reply #14 on: October 27, 2011, 01:19:22 PM »
Thanks Paul.
When I researched the article, I heard all kinds of horror stories.  One was a friend who lost a trailer from behind a motorhome.  The trailer crossed several lanes in the Chicago area, luckily missing all of the cars in the area.  When he told me the story, he was still visibly shaken after several years.  Another friend lost a toad from behind his Eagle bus.  Again, it did not hit a car - went out into a field.
When I towed smaller vehicles, I never gave it a thought. My Jeep tow bar that I built is the butt of many jokes, as it could haul the bus with no problem.  That is my typical approach, build my stuff very stout.
When I started towing the service truck (9600 pounds with full compliment of tools and product), I got very concerned about towing safety.  I vowed that it would stay behind the bus under any condition.  My tow bar was rated at 10K and that did not give me a warm fuzzy.  The cables that came with this bar were a joke.
Like you, I see terrible situations just waiting to kill someone.   One of the major problems I see are commercial trailers with very small grade 30 safety chains and cheap Chinese slip hooks .  Grade 70 chain has over three times the strength of grade 30 chain (what you find at your hardware store and flea markets).  I also used Grade 70 slip hooks which have the same strength as the chain.
Jim Shepherd
Evergreen, CO
