June 25, 2018, 09:04:18 AM
Author Topic: heip 8v92 ddec2  (Read 28998 times)
Offline Busted Knuckle
Re: heip 8v92 ddec2
« Reply #90 on: December 01, 2011, 08:50:31 PM »
After they installed two new  8D batteries the voltage appeared to stay more consistent in the mid 12v range fwiw
Ace I understand what yer saying, but if they truly want to rule it out my suggestion is the easiest way.
And anytime I have a PIA problem like this I like to rule out as many possibilities as possible!
Offline rv_safetyman
  • Jim Shepherd
    • Bus Project Details
Re: heip 8v92 ddec2
« Reply #91 on: December 02, 2011, 04:58:37 AM »
BK, the part that is mounted to the head in the return line is a "restrictive orifice".  According to my manual it is an 0.080 orifice.  I can't imagine why it would have to be changed.  On an Eagle there is not a check valve in the return line - only on the supply line to keep the fuel from being siphoned out of the filters back into the tank.
Jim, I recall reading somewhere that some MCI buses have what is called a "lift pump".  I picture it as an electric pump that is located close to the tank to overcome the "head" caused by the elevation that the fuel has to be lifted to get up and over some path before it gets to the first filter.  You might want to check your manual to see if you have such a pump.  If so, that would be the first place I would check.
Jim Shepherd
Evergreen, CO
Re: heip 8v92 ddec2
« Reply #92 on: December 02, 2011, 05:40:17 AM »
Jim just throwing ideas out there! I didn't know if the 8V's had them or not. But I know that on our 60 series it was bad and creating a similar situation. Once changed no mo problem.
Online luvrbus
Re: heip 8v92 ddec2
« Reply #93 on: December 02, 2011, 05:44:43 AM »
Ace will your Pro/Link read the version of software his ECM has ?
Offline Ace
Re: heip 8v92 ddec2
« Reply #94 on: December 02, 2011, 05:58:46 AM »
Clifford I'm not sure, why?
Ace Rossi
Lakeland, Fl. 33810
Prevost H3-40
Online luvrbus
Re: heip 8v92 ddec2
« Reply #95 on: December 02, 2011, 06:34:18 AM »
I was talking with Cole about it not giving any codes on shut down and he was telling me version 151 which he should have with a rebuild from DD if harness wasn't up dated from a 121 version it won't give codes on shutdown.
These thing are complicated with codes ,sub codes ,harnesses ,versions of software and etc lol I found out the Pro/Link and DDDL will only read the primary codes takes the DD software to read and delete the sub codes
« Last Edit: December 02, 2011, 06:41:19 AM by luvrbus »
Offline Hard Headed Ken
  • 1988 Prevost Angola Conversion Repowered With 14L Series 60 & Eaton Ultrashift
    • Link to my engine swap
Re: heip 8v92 ddec2
« Reply #96 on: December 02, 2011, 08:10:32 AM »
I've use a test light, volt meter, LED and resistor, scope or what ever I had at the time to comfirm if the injector was receiving the signal to fire. I've done this many times on fuel injected gasoline engines. I've never needed to use this method on a DDEC, but I think it would work. That way you at least you know if the injectors were receiving the electrical signal to fire. If they are firing after the engine dies then it a fuel supply problem, if not it's an electrical problem.
Ken
« Last Edit: December 02, 2011, 12:02:38 PM by Hard Headed Ken »
Offline jimsflx
Re: heip 8v92 ddec2
« Reply #97 on: December 02, 2011, 09:38:05 AM »
up date bk we changed the backflo valves,on both lines and changed the fuel lines on the engine,going from first filter to pump, then to second filter and on to the engine,still stopped. so back to electical.thanks jim
jim&roenie seagraves sebring fl. 4106-3083
Online luvrbus
Re: heip 8v92 ddec2
« Reply #98 on: December 02, 2011, 10:01:35 AM »
So easy to take the ECM into a DD dealer and have it read you will go broke chasing problems lol just because you tired another ECM doesn't mean much if you have a bad timing sensor.
DD can dig deep into a ECM with their software
Offline robertglines1
  • steam nut
Re: heip 8v92 ddec2
« Reply #99 on: December 02, 2011, 10:25:34 AM »
real dumb!!  put & keep a cold wet towel on it see if it (ddec) still shuts down.  Could just be overheating and shutting down.. cool down a few degrees and restart.  Just like any other computer.  reaching here---but simple.
Offline Flatspot
  • Jr. Member
Re: heip 8v92 ddec2
« Reply #100 on: December 02, 2011, 03:54:13 PM »
Just out of curiosity there has been no discussion about an engine idle shutdown. DDECII has the option for the engine to be shutdown to avoid extended idle.
Is the idle shutdown enabled?
Zuzax, New Mexico (Exit 178 I-40) 12mi East of Albuquerque
1956 PD4104 6-71T
1988 Eagle 15 CC Conversion
1983 Mack W Utility Bed Service Truck (road assistance in New Mexico)
Online luvrbus
Re: heip 8v92 ddec2
« Reply #101 on: December 02, 2011, 04:18:37 PM »
I asked Larry but never got a reply back ? will the fast idle engage on a DDEC 11 if the idle shut down feature is enabled
Offline Flatspot
  • Jr. Member
Re: heip 8v92 ddec2
« Reply #102 on: December 02, 2011, 06:26:57 PM »
Clifford,
I should have known that you would have ask, I missed it.
On the fleet that I worked with, yes but that said there was a way the ECM looked for a input on the power control wiring or brake input signal... I just can't recall specifics other than there were a lot of firmware changes made by Detroit because the drivers had too much time to figure ways around the way the engineers enabled things.
For instance initially they would set the trailer brake to hold the rig and the tractor could idle indefinitely (PTO time in the log) time for a firmware change.
We had a company owner/CEO that wanted a fleet average of 7+mpg and idle time killed the average.
I guess this is a qualified 'yes' depending on the firmware rev of the EEPROM.
Disabling the idle shutdown feature would be a simple fix if that is the reason this engine is shutting down. I wonder if it shuts down while driving?
Larry
1956 PD4104 6-71T
Offline Ace
Re: heip 8v92 ddec2
« Reply #103 on: December 03, 2011, 01:18:35 AM »
Yes it shut down twice while driving it home a short distance!
The idle shutdown was previously mentioned and checked and was determined to not be the problem. There wasn't a way (at least for me) to turn it on or off via the pro-link although it was listed in the parameters.
Ace Rossi
Lakeland, Fl. 33810
Prevost H3-40
Offline jimsflx
Re: heip 8v92 ddec2
« Reply #104 on: December 05, 2011, 03:40:59 PM »
update, took ecm to detroit diesel, no new codes, idel shut down is turn off. they said every thing fine,does anyone know how to turn the hours on the motor to miles? put another restricker in the return fuel line. fired up motor shut down in 10 minutes. thanks jim
