BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
roof airs
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: roof airs (Read 2911 times)
Busnut83
Full Member
roof airs
on:
November 21, 2011, 08:39:38 AM »
I am working on a 98 prevost,,, it has 4 roof airs,,, my problem is only 2 have controls...
the coach has 2 wall thermostats but they must not be connected... question- the roof air with no controls are the vents or are they air conditioners?
Logged
1989, MCI 102C3, 8V92T, HT740, 06' conversion FMCA# F-27317-S "Wife- 1969 Italian/German Style"
Global Moderator
Hero Member
Nick & Michelle Badame
Re: roof airs
Reply #1 on:
November 21, 2011, 03:42:02 PM »
Hi Busnut83,
You may just have dometic penguins that are controlled by the dometic comfort control center t-stst..
If so, each t-stat [comfort control center] will control two roof units via the zone button on the bottom
of the t-stat. Push the zone button and either zone 1 or zone 2 will display set points.
Without more info, this is all I can offer.
Good Luck
Logged
Joe Camper
Hero Member
Re: roof airs
Reply #2 on:
November 22, 2011, 03:52:26 AM »
Agree with Nick but all the motorhome prevos would not be like that only entertainers.
ALSO
Are you sure the 2 thermostats you are looking at arent for the webasto or the aqua hot to control the 2 different cabin zones?
Who did the conversion
Logged
Busnut83
Full Member
Re: roof airs
Reply #3 on:
November 28, 2011, 09:15:19 PM »
dont know who did conversion.... bus sold as a team bus...
Logged
Joe Camper
Hero Member
Re: roof airs
Reply #4 on:
November 29, 2011, 04:54:08 AM »
I can only asssume by that answer that it is probably an entertainer coach and you did not get any documentation on it.
Did you figure out the thermostats or not??
Logged
Busnut83
Full Member
Re: roof airs
Reply #5 on:
December 05, 2011, 05:56:26 PM »
wall thermostats dont control any... they are dometic pinguins... one controls the nearest one without any controls.. ..
Logged
Joe Camper
Hero Member
Re: roof airs
Reply #6 on:
December 06, 2011, 07:24:18 AM »
They have to have d/c 12 volts to the thermostats or they will not work.
Are the displays blank or are they reading something. That will verify if they have d/c.
Logged
Busnut83
Full Member
Re: roof airs
Reply #7 on:
December 06, 2011, 09:32:59 PM »
thermos are blank.
Logged
Joe Camper
Hero Member
Re: roof airs
Reply #8 on:
December 07, 2011, 04:59:18 AM »
OK then that is actually good news it will be easy to fix there is a d/c fuse to them that is burnt.
I would guess the dc distribution panel is up above the driver over the drivers side window/door. Open up that compartment and look for a spade fuse that is blown it will most likely be a small one 8amp or so. Usually they have things marked pretty well if you have what I think you do. If they are not marked go thru the fuses with a continuity tester till you find a bad one.
Are the tanks level sensors working or are they out too. I have seen them on common circuts with the thermos.
Once you get 12 volts to the thermostats your a/c's will begin to work. That is of course, unless that the a/c circuts powering them are not on or functioning correctly either. But they probably are just make sure you have the a/c breakers for the air conditioners on.
Logged
ruthi
Hero Member
Re: roof airs
Reply #9 on:
December 17, 2011, 09:10:44 PM »
Tom, your funny, ha ha. Ed, I have been really good this yr, and I talked to Santa, he said you all can forget it, you been baaaaaad!
Logged
southeast most of the time.
Print
Pages: [
1
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
roof airs
