June 24, 2018, 02:28:18 AM
Author Topic: Couch that turns into a bunk bed  (Read 19277 times)
Offline Kevin Warnock
« on: December 02, 2011, 07:48:48 PM »
I have no idea where to buy this. All I have is this photograph, which I discovered today on the front page of Reddit.com. This is a couch that turns into a bunk bed. Might be suitable for a bus conversion. Thought I should share this.
http://i.imgur.com/T1q8i.jpg
Kevin Warnock
http://KevinWarnock.com - my blog
Offline Oonrahnjay
Re: Couch that turns into a bunk bed
« Reply #1 on: December 02, 2011, 08:13:46 PM »
Nice.  I'd do something like that but it would be bust up my design philosophy (Cocktails for 6, dinner for 4, sleeping for 2).
6-cyl, 4-stroke, Leyland O-680 engine
Offline Brassman
« Reply #2 on: December 02, 2011, 08:29:17 PM »
Someone posted those somewhere, and IIRC, they were big money.
Offline technomadia
  • Zephyr - 1961 GM PD-4106-446
    • Technomadia
« Reply #3 on: December 02, 2011, 08:37:16 PM »
Sweet, indeed!
When I first read the title of this thread, I was expecting to see the couch/bunk setup that the classic GMC Motorhomes used (which the top bunk essentially hangs from the ceiling - http://www.flickr.com/photos/sierra16/4272831604/#)
 - Cherie
« Reply #4 on: December 02, 2011, 08:38:41 PM »
I can see these being $5,000. But maybe a home built version can be designed.
Offline Lin
  • 1965 MC-5a
« Reply #5 on: December 02, 2011, 10:20:23 PM »
My first motorhome had a couch/bunk homemade setup.  There was a hinged panel against the wall that served as the couch back when down.  It may have been 3/4 plywood.  The pillows went in front of it.  To convert it to a bunk, you lifted the panel to be horizontal and placed some removable legs in the front corners that went from the panel to insertion points in the edge of the couch base that were otherwise covered with the cushions.  The kids were young then, so there was enough room for them.
Offline bubbaqgal
Offline bevans6
  • 1980 MCI MC-5C
« Reply #7 on: December 03, 2011, 04:40:10 AM »
That would be easy to build!  neat idea, you'd just have to work out the dimensions and hinge locations.
Offline Depewtee
« Reply #8 on: December 03, 2011, 04:49:07 AM »
This model is discontinued, but I agree with Brian that it would be an easy build (for someone, not me).
YouTube Video
Brian S.
Brian Shonk
Fort Walton Beach, FL (Florida Panhandle)
1981 Prevost LeMirage Liberty Coach
1984 TMC MC-9
Offline gumpy
  • Some Assembly Required
  • Slightly modified 1982 MC9
    • bus.gumpydog.com
« Reply #9 on: December 03, 2011, 05:03:07 AM »
That would be a piece of cake to build! Especially with that video.
Steel frame. Plywood panels. Some cushions.
Couple hundred bucks.
Here's a video that shows some other cool ideas in space saving beds...   Resource Furniture
« Last Edit: December 03, 2011, 05:20:14 AM by gumpy »
Offline Jeremy
  • 1987 Bedford Plaxton
    • Magazine Exchange
« Reply #10 on: December 03, 2011, 05:06:01 AM »
I also vote for building one yourself. There's nothing remotely clever about the mechanism, just a couple of hinges and gas struts.
By co-incidence, just this week I looked into the idea of building a sofabed for my bus, but having seen the mechanism inside of the type of bed I wanted, I decided that this was one thing I would buy rather than build myself - this is what they have inside:
Back to the sofa bunk bed idea, here's another variation:
Lastly, I can't quickly find a photo now, but some long-distance buses also had a system where two forward-facing seats (one in front of the other) would convert into a bunk bed. That type has been discussed on here before.
Offline Hobie
« Reply #11 on: December 03, 2011, 09:23:48 AM »
I call the top bunk !!
Offline Mex-Busnut
« Reply #12 on: December 03, 2011, 09:42:14 AM »
Awesome ideas, for sure. But I can certainly dream up MANY uses for $6,800 (plus shipping, I am sure!) in my bus, including buying 1,700 gallons of diesel fuel.
Jake brakes
Offline Barn Owl
  • Roanoke, VA
  • PD4106-1063 "Wheezy Bus"
« Reply #13 on: December 03, 2011, 07:47:06 PM »
Brilliant!!!
Offline gus
« Reply #14 on: December 03, 2011, 08:32:22 PM »
It probably doesn't apply in this case of a folding bunk bed but one idea I always apply in bus beds is that there is no need for the box spring base normally found in home bed sets.
I use a simple plywood base and any height you want and make a nice foam mattress of whatever thickness or firmness you want. Those commercial mattress foundations are just overpriced junk anyway.
My 4104 has a nice walnut folding bunk bed set that makes into a sort of couch. Not elegant but it works. Only problem is a couple of bolts have to be removed to convert. Since we never used the couch part it doesn't matter to us. It is , however, a nice piece of custom carpentry by someone.
