June 23, 2018, 05:20:55 PM
Author Topic: AC units?  (Read 7684 times)
Offline Flight102C3
  • Jr. Member
AC units?
« on: January 31, 2012, 06:08:33 AM »
Hi!! hows everybody doing??  Got a question about what the best AC unit would be?? I need to rought in ducts,elc.
Are all RV style AC the same for rough in??  Where would I find a site that would help me?? Thanks for now.
Offline Mex-Busnut
Re: AC units?
« Reply #1 on: January 31, 2012, 06:29:00 AM »
What kind of bus do you have?
Some of us wierdos are installing home-style mini-splits and keeping our roof lines cleaner and lower. Plus they cost half of what a roof top unit costs. In my case, they only draw 9 amps max, compared to 15-20 for rooftop units. Just another option for you to consider.
Jake brakes
Online luvrbus
Re: AC units?
« Reply #2 on: January 31, 2012, 06:47:41 AM »
The RV roof tops are 14x14 openings
Offline belfert
Re: AC units?
« Reply #3 on: January 31, 2012, 09:21:15 AM »
Where are you buying mini-splits for half the cost of a roof top?  Are the prices in Mexico that lop sided because mini-splits here in the USA seem to cost around the same as a roof top.
Offline Flight102C3
  • Jr. Member
Re: AC units?
« Reply #4 on: January 31, 2012, 09:41:28 AM »
I have a 102C3.  Don't know any thing about a mini split!! needing info about the space between roof and ceiling for the internal duct work and cold air return
Offline Mex-Busnut
Re: AC units?
« Reply #5 on: January 31, 2012, 10:45:06 AM »
Here in Mexico we paid 6,300 pesos for each mini-split. These also have the heating elements installed. Each rooftop unit would cost us 14,000 pesos down here. Exchange rate is about 13.5 pesos per dollar.
Jake brakes
Offline belfert
Re: AC units?
« Reply #6 on: January 31, 2012, 12:58:36 PM »
I used to have a travel trailer with ducted A/C.  The ducts were maybe three inches tall.  I suggest finding the installation manual for a rooftop A/C and it should list the required dimensions for the duct work.  Typically the duct work is sized in square inches of area.  There is a fair bit of leeway in how wide and tall the duct work can be as long as the square inches are right.
Mini-splits require no duct work.
Offline uemjg
  • jerry
Re: AC units?
« Reply #7 on: January 31, 2012, 01:23:37 PM »
I live in Houston and wondered where/who could I order a mini split from? Brand? more info?
Offline bevans6
  • 1980 MCI MC-5C
Re: AC units?
« Reply #8 on: January 31, 2012, 02:10:02 PM »
Steve, how many BTU's are they each, for 9 amps (at 120 volts?) and is the 9 amps for both units (evaporator and condenser?)
Offline Timkar
Re: AC units?
« Reply #9 on: January 31, 2012, 02:59:04 PM »
As posted by Bob a while ago.....http://www.minisplitshop.com/store/home.php
HTH....Tim
Cawston, British Columbia
Online luvrbus
Re: AC units?
« Reply #10 on: January 31, 2012, 05:38:32 PM »
UEMJG, living in Houston should be no problem finding a Goodman mini split they are made there,huge plant they make units for all the major manufactures
Offline Oonrahnjay
Re: AC units?
« Reply #11 on: January 31, 2012, 05:50:01 PM »
     Here is a section from a "single-zone" mini-split product specification:
Type    Rotary/Scroll
RLA (Amp)    4.5
LRA (Amp)    26.0
     What do the RLA (Amp) and LRA (Amp) numbers mean?
6-cyl, 4-stroke, Leyland O-680 engine
Offline uemjg
  • jerry
Re: AC units?
« Reply #12 on: January 31, 2012, 06:07:12 PM »
I guess I should have been more clear on my request...I was replying to mex-busnut as to where in Mexico I could buy a mini-split.
Online luvrbus
Re: AC units?
« Reply #13 on: January 31, 2012, 06:09:07 PM »
Bruce
RLA= rotor locked amps (running)
FLA= full load amps
LRA= load rated amps
« Last Edit: January 31, 2012, 06:22:54 PM by luvrbus »
Offline Mex-Busnut
Re: AC units?
« Reply #14 on: January 31, 2012, 06:58:25 PM »
Are you in Mexico? I am 100 miles North West of Mexico City. I bought them here in town. I would imagine buying them and shipping to the U. S. would cost an arm and a leg.
Here is the tag on the box. I exaggerated when I said "9 amps". They take 8.5 amps max. They are 12,000 btu each.
Jake brakes
